Home > In Car Electronics (L322) > 2011 climate contol dash in to 2002 RR |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I don't believe so .You can fit a 2006 to 2009 panel though. Present :2008 TDV8 HSE
26th Aug 2014 11:33am |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Will be following as looks interesting! Accept, some days your the pigeon, some days your the statue! |
26th Aug 2014 12:48pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
if people are interested in this I will try to document it here |
26th Aug 2014 1:28pm |
Id be well interested! Would be a nice update from my 2004! Accept, some days your the pigeon, some days your the statue! |
26th Aug 2014 1:44pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
You've got more chance of fitting the one without climatic seat controls. Just use the Vogue one. The one you have is Vogue SE and Autobiography standard fit. |
26th Aug 2014 5:45pm |
ibb1 Member Since: 27 Sep 2013 Location: London Posts: 80 |
Also where will his air susp info go?. |
27th Aug 2014 7:57am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
as above ^, where will you put the suspension mode control,
27th Aug 2014 8:12am |
this is what I have now
27th Aug 2014 11:24am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Is it my imagination or are all the controls on that new panel in the first post the opposite way round to the ones in most peoples' FFs??
27th Aug 2014 11:33am |
no you are correct DT, why they put the heated front/rear demisters on the far left initially i dont know.. ... - .- -.
27th Aug 2014 11:35am |
got the first part done today
30th Aug 2014 1:58pm |
so you just using the knobs and not the switches then? ... - .- -.
30th Aug 2014 4:47pm |
well to start with yes
1st Sep 2014 3:45pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Would this fit 2005-2009 dashes? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Sep 2014 12:21pm |
