Home > Maintenance & Mods (L322) > fitting front mud flaps.. DIY or dealership?
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
how hard can fitting front mud flaps be??
Sad
i got a front set of ebay ..came with 12 screws /washers and 4 sleeve washers and good fitting non OEM flaps.
went to look at the fitting instructions from other threads here..
there seems to be some additional panel that is need which i have no got.
should i return the flaps or have members done with out this additional part or just let the dealer fit it.
any advice please
the rear one took 10 mins per side.
front ones are a PITA....
thanks raj 2011 4.4 TdV8 Nara Bronze
Post #277205 23rd Aug 2014 10:03am
the bottom panels just behind the front arch has to come off to fit a metal plate which the flap bolts onto.you have to drill two hole into this panel as well.. ... - .- -.
Post #277208 23rd Aug 2014 10:14am
Vogue
To find out how to remove the lower panel there is a thread on replacing the side vents/grills this also details how to remove the lower panels - easier if the doors are open 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #277211 23rd Aug 2014 10:47am
goldsax
its the plates that i am missing..
have i read correctly that some members have got away without placing the plate but are using large screw/washer/bolt?
Post #277212 23rd Aug 2014 10:49am
Googsy
Did you buy aftermarket versions if so they tend to send out without plates. Originally I bought these and they came without plates after contacting supplier they sent me out missing brackets. I now have original oem flaps. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #277217 23rd Aug 2014 12:10pm
goldsax
thanks for the info ..
yes aftermarket (nonOEM)
will contact supplier to see if they supply the plates as well.
cheers raj 2011 4.4 TdV8 Nara Bronze
Post #277221 23rd Aug 2014 1:15pm
If the side panels have never been removed, it'll take a fair amount of effort to get them off, so you need to be a lot braver than you think! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #277225 23rd Aug 2014 1:26pm
