![]() | Home > Maintenance & Mods (L322) > Maybe pcv valve |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Nothing specific as it could be the rear crank seal gone instead or cylinder head/rocker cover leak. You need to stick your nose over the back of engine and have a look. Remove acoustic cover and heater air intake scuttle (2 nuts) and have a look at the hoses at the back. |
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
Thanks jock,two hoses replaced 2012 and still look ok. I noted your previous comments and the two videos where the guy says 70k replacement mileage . I have all the service sheets since new,and no sign of pcv replacement,mileage now 130k. Did you do yours? I am at present doing camshaft cover gaskets and washers, but am concerned that if I close those leaks and there is crankcase pressure then it has to go somewhere. When I have it back together, I will check the dipstick pressure |
Yes I did mine as like you say, I didn't want the new rocker gaskets sealing it up if the PCV valve was blocked. The valve is about £35 so won't break the bank (use BMW part 11617508541, LR part LKR000040 is over twice the price). I guess you could remove and clean the old one assuming it's functioning correctly.
