Home > Camping, Caravanning and Holidays > 12v TV connector lead
Stormin
2003 Range Rover HSE Td6 Epsom Green
Just bought my first caravan and thinking of purchasing a TV, have read else where that most modern TV will run on 12v if they have the brick in the mains lead.
My question is does anyone know where I can find an adaptor, hopefully I've attached a picture of something similar.
http://www.ebay.co.uk/itm/Cloverleaf-C5-to...3f25ec91ee
The only problem I can see it has 3 pins not 2
Cheers Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #276745 20th Aug 2014 8:10pm
Hmm, depends what the output of the brick is. The brick is the transformer which steps the voltage down, so if you put 240v into the brick you get x volts out. If x is 12v then connecting the tv to the caravan will be fine. Have a look at the input voltage on the sticker on the back of the tv or the output voltage on the transformer.
However, you will need to intercept the cable on the tv side of the brick and insert a connector between the brick and the tv, so you can swap between power from a brick and power from the 12v caravan supply.
Feeding 12v into the brick will not work........
If you can disconnect the whole caboodle from the tv then a 12v cigar lead with the appropriate connectors will suffice running directly from the 12v caravan socket, so long as the TV runs on 12v (see labels) There is nothing that can't be fixed with a hammer😜😜
Post #276746 20th Aug 2014 8:18pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Wiring for a 12V Outlet
First find the output power and voltage from the brick that powers the electrical device - in most country's it is mandatory to have this on the power brick label (although you often need a small magnifying glass to read it).
For my 50cm TV it reads 12V, 3A and has a DC symbol (solid horizontal line above dashed horizontal line). If you multiply these together you'll get 12V * 3A = 36VA (VA = Watts for non inductive loads, add 20% for anything with electric motors). If the low voltage output A, VA or W is not reported you can calculate it from the input V and A (or VA or W) as the input will be equivalent to the output + 10% for conversion losses.
The label should also indicate the polarity of the connection to the device, most will use a barrel type with the hollow centre being the +V. This is most often shown graphically as a + sign inside a capital C with a - sign attached to the middle left of the C. If the picture is a capital S on its side the output is AC and the solution isn't so simple.
If the label is missing use a multimeter to check the output from the brick (if you don't already have one go to a cheap (pound) store NOT an electronics or auto store, you'll get a small, workable one for under £5). Most good stores can be persuaded to allow a test of the brick while not connected to anything . . .
Measure between the inside and outside of the barrel connector on the 20V DC scale. With no device connected the no-load voltage should be somewhere around 18V. Record the voltage and whether the centre (inside) of the barrel is +V or -V. If the reading constantly changes try the 20V AC setting Crying or Very sad
If the device is for 12V DC at or below 10A then you are in luck. [12V DC is a 'generic' term for 11 to 14V DC, which is the usable range in a car; 13.5 to 14.2V with the engine running down to 11V minimum required to operate the starter motor] There are several choices for providing power - 1) a dedicated cable with the correct plug on the end, 2) a single 'cigar lighter' receptacle on a wire, plus a cable with sockets for the cigar lighter and the device at either end 3) a single 'cigar lighter' receptacle in a wall plate outlet, plus a cable with sockets for the cigar lighter and the device at either end, etc.
A typical DC outlet will handle 10A easily, so long as heavy enough cable connects both the +V and -V all the way to/from the battery (use a fuse !). However screw terminals or Anderson plugs are recommended for higher power devices. These are simple and cheap to fit, they can be found at automotive stores, caravan suppliers and ship's chandlers (outdoor, waterproof types).
If the device is AC or any DC voltage other than 12 to 13.5V then a 200W DC to AC inverter may be used with acceptable losses of ~20%. You will have 12V Battery DC --> Inverter 220V AC --> Power Brick --> Device.
bye.
Post #310425 4th Feb 2015 5:50am
