Home > Technical (L322) > Turbo squeal STILL. Help save my RR because I'm done :(
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
finally got to the bottom of this and found out the problem exhaust manifold leaking ,took it in to my local indi and they have stripped it and sent the manifold of to be machined ,hope it solves the problem.
Post #285185 9th Oct 2014 7:56am
Just as an outside thought, the crankcase breather. Have you fitted the newer version at all?
Are you getting a good boost reading when it's picking up? If you have diags your welcome to pop by and we can compare apples with apples? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #285613 10th Oct 2014 10:46pm
cowman
yes i have fitted the later crancase filter ,havent got it back yet from indie
Post #285761 11th Oct 2014 2:25pm
That's good as that's been known to cause turbo failure. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #285846 11th Oct 2014 7:13pm
RoryM
Ireland 2008 Range Rover Vogue TDV8 Santorini Black
I think mine has this same issue. has had for quite a while now. just out of curiosity, how would I diagnose this and how much to remedy?
Rory.
Post #286247 13th Oct 2014 1:08pm
cowman
got mine back from garage all fixed did the manifold changed both belts ,400 pounds,bargain i thought it takes 6.9 hrs to change exhaust manifold gaskets,also changed the down pipe if yours has got a aftermarket one one ,it makes a zinging noise up the rev range as though you have got a leak .
Post #288838 25th Oct 2014 1:37pm
mjdronfield
That's exellent news. You won't have to worry about that issue again.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #288846 25th Oct 2014 2:12pm
