![]() | Home > Wheels & Tyres > "L322 fitted with L405 wheels" thread |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I just swapped the wheels over and used the wheel nuts that were already fitted to the car.
Mick B Member Since: 02 Apr 2021 Location: Northfleet Posts: 4 ![]() ![]() |
Thanks Jim, the only problem is this is the third set if wheels I've had on my RR, the first were 22" low profile, which were on there when I bought it, I then replaced them with 20" black rims with black nuts, so I'm kinda starting from scratch again, as the new L405 rims are a silver finish. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
how old is your FF Mick?..if after 2006 then you would have the larger nuts so they will fit the L405 wheels. ... - .- -.
Hi Stan,
should be,
Perfect. Thank you Stan.👍 |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
Style 1065 with 255 55 20s
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 ![]() ![]() ![]() |
I’m digging your overall look; not just the wheels ![]() |
kesterriley Member Since: 04 Dec 2021 Location: Bognor Regis Posts: 4 ![]() ![]() |
I have added these beauties to my L322 today.
L405 21" wheels style 7001 with 275/45/21
Love that look… 👍🙏👍 |
Thanks Craig. I've made a.minor adjustment this morning removing the wind deflectors and adding the silver grill again to go with the wheels
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
Apologise for the daft question
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
These wheels work surprisingly well, nice one! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
