![]() | Home > Technical (L322) > quick question |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
I'm no expert but for what its worth I do the following.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Thanks for the quick reply.
Don't forget when reconnecting, Pos lead first then earth. After starting the car turn the steering hard left then hard right to reset the steering. |
I'm not sure if it's of any use to you but there is a permanently live 16mm2 cable fused at 100A at the rear of the car.
Thanks for the replys.
Connecting into the rear cable wouldn't have caused any problems, it's a direct connection to the battery +ve terminal.
Cheers |
Thank you everyone. The hoist is up and running.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Post a few pics up when you have done. Good to see how you have done it.
When I have a spare hour I'll post some pics.
I can recommend Ashley 4x4 if you need any work done on the rr. They are local and Land Rover trained.....
Thanks very much I've been past their place a few times and did wonder, but a lady in our village used them and did mention it. Where I used to live at hednesford I used mercia 4x4 for my disco's but a bit far to go now.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I've a pal in rugeley who's got a machine shop and is a 4x4 expert just off power station road, they do engines that others are scared to do including for car SOS TV prog |
Scottyav. Noticed from previous posts your local. Its good to know we have a few good places
