Home > My Range Rover > Behold the SHINY
Page 3 of 5 <12345>
Think I may have found the source of the shudder.
There seems to be greasy deposits on the inside of the d/a wheel, bottom rear of the strut and round the front caliper banjo fitting. So it looks like tit was leaking fluid, which has mixed with brake dust. So nipping this up combined with the new pads should hopefully sort it, had lost a bit of fluid too, so looks like the culprit.
Enjoy the break Stan! There is nothing that can't be fixed with a hammer😜😜
Post #280276 10th Sep 2014 9:41pm
Rolling Eyes Well sneaked in. Thumbs Up
Post #280281 10th Sep 2014 9:58pm
Big Cry Censored predictive text..... There is nothing that can't be fixed with a hammer😜😜
Post #280295 10th Sep 2014 10:33pm
Freudian slip more like. Laughing
Post #280296 10th Sep 2014 10:35pm
thanks Mark. Thumbs Up ... - .- -.
Post #280320 11th Sep 2014 6:57am
Nothing worse than a leaky tit Discovery 4 HSE
Post #280339 11th Sep 2014 8:24am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
RRUK..Nothing worse?..a leaky flange Big Cry GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #280342 11th Sep 2014 8:33am
I haven't read this thread and the last two posts have put me right off delving any deeper Very Happy
Post #280347 11th Sep 2014 8:44am
Googsy
Yes MODs should know better and lead by example have Pm'd the impeccable Martin Very Happy Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #280372 11th Sep 2014 10:32am
deffo wasn't a flange leaking looks more like a bleed nipple......... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #280383 11th Sep 2014 11:58am
Badge update done!
Toffee wheel is a total boon, gets rid of the sticky stuff easily, just needs a steady hand and a drill which will run slowly, I suspect you could do some paint damage if it ran too fast!
Now have Titan front and rear badging and Titan boot strip, just lifts the car that little bit, brunell always looked a bit dark to me! Just need a Titan vogue badge now, tempted to get an AB badge but that might spoil it a bit????? And it isnt!!!! But it's so tempting.
Gave the car a quick mop over with the da and polishing pad, not a full polish but made it look a bit tidier.
Also swapped to the rubber mats in prep for the terrible winter we are bound to have! There is nothing that can't be fixed with a hammer😜😜
Post #287607 19th Oct 2014 7:19pm
Googsy
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #287644 19th Oct 2014 11:31pm
....He says whilst holding on to a large piece of wood!
Niggles done!
Expansion tank hose replaced
Read wash wipe fixed
Quick oil change done
Coolant dropped and changed when they did hose
Transfer box leak checked and all good
Quick charge on the ctek
Winter wheels and tyres put on
Anyone think of anything else I should do in prep for a miserable winter.... Otherwise it should be good for France trip! There is nothing that can't be fixed with a hammer😜😜
Post #309313 30th Jan 2015 6:34pm
johnboyairey
pld118 wrote:
Laughing ... Think I insulted the mechanic who fitted our rear brakes at the weekend by asking him to please make sure he used the supplied tube of copper grease instead of the stuff he used before as I'm wondering if that's maybe why the fronts are squealing!
Thanks.
I have seen the effects of a internally collapsed flexible brake pipe, like the ones on the front calipers, it breaks down, and blocks itself up, it restricts the flow back of fluid and seizes the brake caliper a little. I know we are talking rear, which ( I'm guessing) have a single flexy for the rear axle, but it could be worth sticking on a new one whilst the fluid lines are open etc. It could be biasing one caliper more than the other....
Flexies -Possibly around £20 worth.
Post #309389 30th Jan 2015 11:45pm
Well I got the expansion hose changed and checked it this morning. It is fine but in changing it the garage seem to have damaged the hose above it where it joins the ally hose Union. And it is leaking a bit Big Cry
I know how the ended up damaging it! It is a pita to get off. Not really their fault.
Upside is that the bargain hose set off of the bay of E which I bought to fix the first hose has the second hose attached. So in the end I changed the second one this morning.
fyi the hose to the small rad in the wheel arch is sooo much easier to change if you take the drivers headlamp out! Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #309717 1st Feb 2015 3:31pm
Page 3 of 5 <12345>
