Home > Maintenance & Mods (L322) > identification of piece
paulvogue
Hi there might seem a really stupid question ...but i recently had some work done on my 2004 td6 (front timing chain cover replaced)as i didnt have the time to do it myself, the person doing it then got way laid so i have now had to put it back together myself, which wouldnt have been so much of a problem had i dismantled, as i have already done it in the past. I seem to have located the positioning of all the parts bolts etc but i just seem to have one piece left that i cant find where it locates...its a black shape small bracket not sure if its even body work related possibly something to do with bonnet catch but in reality could be anything ...i have attached a picture can anybody identify it please Question Question Question many thanks
Post #266559 21st Jun 2014 10:51am
i dont what it is but you could have a look on microcat (links in wiki) ... - .- -.
Post #266560 21st Jun 2014 11:41am
paulvogue
thanks anyone got any clues to seeing this part before?
Post #266589 21st Jun 2014 3:47pm
Bigsteve
Is it one of the brackets that the plastic engine cover clips into?
Post #266655 21st Jun 2014 11:19pm
paulvogue
Just had a check cant find anything that looks like its missing a bracket like that it has a rubber bung through it, its a mystery i assume someone else will have had that part off when doing similer work ...hopefully Confused
Post #266737 22nd Jun 2014 3:08pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Think Bigsteve is right, it does like the bracket from under the grey top engine cover. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #267165 24th Jun 2014 8:29pm
It is an engine cover bracket, secures one of the allen bolts. It is fixed to two of the upper inlet manifold bolts, just beyond the third diesel injector from the front. .
Post #267198 24th Jun 2014 10:19pm
