![]() | Home > In Car Electronics (L322) > Options on new keyfob |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
Read davo's posts on keys Paul 1994 softail full stars n stripes custom harley davidson |
Keys for your car are GBP125 from Dan at Duckworths and there are instruction on here to sync the keys without paying a dealer to do it .
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Just my 2p, and I know it's not always the case, but blank keys bought over the internet can be made from all sorts of strange mixes of metals.
My key works fine and it's from china and it's a flip to
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 213 ![]() |
What year is your car? Facelift? Terrain response etc?
Does everything auto close an open windows sunroof doors
Before things get too muddied here the, OP asked what are his options for a NEW key not how to make a flip key from and older BMW key am I right ? in which case a new key has to be ordered from a dealer. No specialist can make a key because it needs the coded transponder in the key to make the ignition unlock and turn , blades can be cut and fobs can be made to unlock the central locking but without he transponder from Land Rover nothing will start . 2008 MY Supercharged
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
I'm in the same situation really, I've only got one key. The ONLY way to get a second key is to buy from a dealer? |
Yes, but what year is your car? |
With regards to keys, there are a few options.
OK, I went into a key cutting shop thatalso do car keys. He said he could program the transponder, so it would work in the ignition, but it wouldn't remotely open the car. So can I get one of these keys and then program the. Key to open the doors? |
Paul mine is a 2003 Vogue but like I said look up daveos threads on this forum he has all the info he even has a video how to program the keys for locking an unlocking the doors 1994 softail full stars n stripes custom harley davidson |
paul r Your key guy must be talking about a BMW based car yours is a TDV8 and as such is some times referred to as Ford based either way you must order a key through a dealer via your VIN number THERE IS NO OTHER WAY TO GET A KEY THAT WILL START THE CAR .
MaximusMorey Member Since: 13 Jul 2016 Location: swanley, kent Posts: 4 ![]() ![]() |
Hi guys,
