Home > Technical (L322) > SC Gearbox problem |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2254 |
Taking my SC into dealer tomorrow to take them for a test drive to show what is happening with seriously harsh gear change on kick down. It has been in twice already and they have updated software but I think from reading other posts this is a physical prob something is not right. It has a delay on changing down and then a really hard thump into gear but only when travelling quite quick so we shall see.
17th Jun 2014 12:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35249 |
seems to be a spate of gearbox related problems lately , hope yours gets sorted and isnt to expensive.. ... - .- -.
17th Jun 2014 12:32pm |
Hi Sandyt, can you please get the fault codes read as to give us an idea.
17th Jun 2014 1:12pm |
Thanks ebajema will do I had read your posts which got me thinking I still have LandRover warranty on the car but so far everything I have tried to have fixed on it has been "wear and tear" so am not expecting a lot. Interestingly both times they looked at it they say there are no fault codes personally I don't think they read them just assumed it was a software issue. With your permission I will show them your posts on this. |
17th Jun 2014 2:52pm |
Dealer is taking it in and going to send readings from the gbox and the engine to the factory - they have logged the fault with the warranty company. To be honest they were very good and want to get it resolved before the warranty runs out next feb. Will keep you posted |
19th Jun 2014 11:23am |
Thank you I shall |
19th Jun 2014 7:07pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Don't get me started on fault codes! My D1V8 had the alternator back it in. By the time I got to the mechanic's place, I was on about three cylinders as petrols don't tend to work very well without electricity. No fault codes. Now everything is running nicely, I get random fault codes (and as it the D1 not an FFRR, I just ignore them).
19th Jun 2014 8:10pm |
Update on gearbox prob dealer has had it for a week they have sent all the readings from the engine and gearbox to Landrover Technical at the factory who came back with a check for any metal flakes in the transfer box - they have found them and have been advised by Landrover technical to replace the gearbox and transfer box Landrover Warranty sending assessor tomorrow
10th Jul 2014 3:07pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Have you got the LR "Select" warranty Sandy?
10th Jul 2014 6:08pm |
Yes I have the select warranty and in fact they had twice done software updates - small improvement but when I went back to dealer they wanted to get the fault logged as on 97k and warranty runs out next feb and won't be replaced due to milage. It was the factory that gave them the info will keep you informed as to what happens |
12th Jul 2014 5:21pm |
Thanks Sandy |
12th Jul 2014 7:49pm |
Right Gents here is an update
17th Jul 2014 8:39am |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Nightmare situation. So often the warranty is just not worth the paper it's written on.
17th Jul 2014 8:51am |
To be honest I want to pay the silly money as it will motivate me to nail them - and I will Its not that I can't afford it its that they are being unreasonable its just a waste of a grand because I know it won't solve anything and so does the dealership - The dealership have offered to do it at cost and half labour rate as I have them do other work so it will be less
17th Jul 2014 9:00am |
