Home > Off Topic > Ride on Lawnmower Lawn Tractor
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Hi guys
Hve just bough a house with 2.5 acres of lawn, I need something to cut the lawn. I have been round a few or my local garden machinery outlets and not unsuprisingly they all tell me the brand of mower/tractor that have is the best.
Any advice from those who have a lawn tractor/ride on mower would be much apperciated, any thing to look out for? models to avoid?
I am not wishing to spend more than £3k so currently thinking either John Deere X165 with collector, an X155r or Mountfield 1840H (5 year warranty) as they have the 2 cylinder engine (I have a couple of slopes so probably need the twin cylinder)
Not sure if I need to collect all year round or mulch the grass during the summer, but would collect in autumn to get the leaves off the grass.
Andrew 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #264921 12th Jun 2014 12:44pm
Advanced Factors
Site Sponsor
Asked that question myself over the other side...
http://www.disco3.co.uk/forum/topic111190.html
Extra opinions might help Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #264924 12th Jun 2014 12:50pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Andrew...Have used the previous model to this one (no visible difference to mine) for the past 12 years and has cut a lot of grass in that time, gets an annual service and has never let me down,great bit of kit and when he time does come will definitely buy the same again. Thumbs Up
http://www.etesia.com/en/products/ride-on-mower-bahia-mhhe.html The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #264935 12th Jun 2014 1:10pm
mbdj
Re: Ride on Lawnmower Lawn Tractor
Countax/westwood with powered grass collector Thumbs Up
Post #264946 12th Jun 2014 1:31pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Andrew,
I have a Countax C600H. It has a PTO at the back which works with various attachments. Within my garden are 18 oaks which generate 3 -5m3 of leaves annually. The grass collector sweeps the leaves (best when dry) which i then chop down for composting with a 42inch cutter-deck.
I also have various attachments, scarifier, sorrel roller, 38inch mulching deck, broadcast spreader all used through out the year. My SCH plastic trailer has moved everything around.
I bought all from Fairlawn in Kent (Alan) with the exception of the scarifier from Hugh Page in Sussex.
Both were open for negotiation on all - Alan especially as he has also supplied 2 further units to neighbours over here.
Good luck
Post #264947 12th Jun 2014 1:35pm
get lots of Sheep andy....... ... - .- -.
Post #264952 12th Jun 2014 1:58pm
kiter
Got about the same amount of ground but mine has a few fairly steep slopes - had a Countax, pile of rubbish and heavy on fuel. Replaced it with a Stiga out front mower (4wd and diesel) great bit of kit. Frank Nicol in Dingwall are local dealers but I tend to go to Inverurie - guy in service dept there is very helpful and knows what he is talking about.
Bought mine as an ex council machine on ebay (£1800 plus £175 for pallet delivery from Devon) and apart from a new set of belts and engine services it has needed nothing. Its a mulching deck so as long as you keep grass short no clippings to collect.
Post #264981 12th Jun 2014 5:39pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Agree with Stan's choice, the only mowers you can eat at the end of the growing season.
Post #264984 12th Jun 2014 6:09pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
John deer zero turn I had half dozen different ones john deer was the best 1994 softail full stars n stripes custom harley davidson
Post #264994 12th Jun 2014 6:40pm
A1GSS
I had a Countax C600H. Thumbs Up Pretty good, only thing I discovered was that after the clippings pile got large, emptying the collector was a pain. Friend had an Iseki with a lifting device to empty the clippings. More expensive but all round better quality. Diesel. Bigger. If you can afford it I'd suggest you take a look.
If you have slopes., go for 4WD.
http://www.franknicol.co.uk/products/Iseki...ector.html Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #265002 12th Jun 2014 7:07pm
Andy_J
Thanks for the suggestions, most of the mower are a bit more than I have to spend unless I can find one second hand. Would love to get a diesel. Anything I should look out for on a second hand?
Stan/Oldcro sheep were considered, as I have a field which I have horses in (another 2 acres), but they deposit too much for me to let them on the lawn. They do eat all the grass clipings from my 18" cut mower
I have 2.5 acres of trees so do need something which will pick up the leaves in the autumn, don't think anything with a front deck would work
Kiter - I work in Dingwall, so I pass FrankNicol every day, they have suggested the Mountfield, MacGregor forest and ground care suggested the John Deere. Neither dealer suggested the other brands they do.
I do have an Iseki 2160TX compact tractor, but it has a backhoe (pain in the arse to remove), so grass topper is an option, but not ideal 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #265011 12th Jun 2014 8:00pm
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I have a Countax and would definitely recommend. Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #265029 12th Jun 2014 8:39pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have a John Deere - hasn't missed a beat in 3 years and parts seem very cheap relative to the competition. 4.2 Supercharged Vogue SE
Post #265036 12th Jun 2014 8:46pm
Andy_J
The Countax does look good but the 600h is £4K 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #265037 12th Jun 2014 8:47pm
I needed one for the current place and didn't want to spend Countax money, I bought a Craftsman, US Brand, same machine as sold under Husqvarna.
42" twin blade cut
centre chute for grass removal (doesnt clog up like side exits)
Hydrostatic gearbox
Mulch and collect system
Was about £1750 Discovery 4 HSE
Post #265055 12th Jun 2014 9:21pm
