Home > Technical (L322) > Reverse camera fuse? |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 |
Does anybody know if there is a fuse for the reverse camera I've fitted another new one and I'm just getting a black screen now? F**K IT you only live once |
12th Sep 2014 3:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
normally a battery disconnection helps, details in the wiki.. ... - .- -.
12th Sep 2014 3:34pm |
Cheers Stan will give it a try fingers crossed cause there's a guy coming to buy it tomorrow F**K IT you only live once |
12th Sep 2014 3:38pm |
Tried disconnecting the battery still no signal? Any other ideas? F**K IT you only live once |
12th Sep 2014 8:48pm |
i suppose you could fit the old camera and see if you get a picture, this could indicate that the new one might be faulty or you have connected it up incorrectly.. ... - .- -.
12th Sep 2014 9:10pm |
Yep I could do that Stan, if the old one worked F**K IT you only live once |
12th Sep 2014 9:55pm |
Just hooked up the IID tool and it's saying the reverse camera is undefined??? Any ideas what that means? Maybe a duff camera F**K IT you only live once |
13th Sep 2014 8:04am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Had this when mine went blank - the fuse for the camera is in position 12 ( 5A) is in the back - I just looked at all the 5a fuses till i found one that was burnt out - replaced it and it worked - no longer undefined!!
13th Sep 2014 8:13am |
Brilliant RP you are the man probably could have saved myself the cost of a camera but hey ho F**K IT you only live once |
13th Sep 2014 9:20am |
