Home > Maintenance & Mods (L322) > Exhaust Tips
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Exhaust Tips
Lo Peeps
Need advice on what would be the best thing to do with these sad looking tips
They can't be cleaned as they are pitted Crying or Very sad
So was thinking new custom exhaust = probably out of the question due to pending horrendous vet bill.
Get them taken off ( if this is possible ) and get re-chromed.
Get new tips = probably going to be to expensive
Am open to suggestions Thumbs Up
To me its the only thing that really spoils the car Big Cry
 Current : 4.2 S/C, now Sold Sad
Previous : V70 Volvo, S40 Volvo ( a very reliable old banger ), E39 M5, Carlton Diplomat and the list goes on Smile
Life Sucks but ya just have to do the best you can with what you have !
Post #261856 28th May 2014 12:56pm
ebajema
See if you can get stainless steel pipe that fits tightly over these. Polish those and fix them with hi temp Loctite.
You can always change them out that way. MY 2010 5.0 SC Galway green and sand interior!!
Post #261857 28th May 2014 1:05pm
Muttley
Thanks ebajema , sounds like a plan that wouldn't cost the earth Thumbs Up
Cheers
Dave Current : 4.2 S/C, now Sold Sad
Post #261881 28th May 2014 2:35pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine looked like that until about a year ago until, whilst lying under the car, I realised they were supposed to be shiny. I gave them a good clean with hot water, then with engine degreaser, followed by a couple of sessions with chrome polish. They looked great and it was relatively cheap and simple.
The family thought polishing a bit of pipe under the car very sad, but for us blokes the simple pleasures are hard to come by nowadays. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #261932 28th May 2014 5:58pm
Googsy
Mr muscle oven cleaner Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #261969 28th May 2014 8:00pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I am sure you could improve them. ( though I do like Eugenes idea of some kind of custom made "sleeve")
A quick Google returned this :
http://www.incrediblydetailed.com/how-to-clean-exhaust-tips/
http://www.bssa.org.uk/topics.php?article=77
I use autosol metal polish, off to buy #0000 steel wool to apply it with Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #261975 28th May 2014 8:50pm
Muttley
@ RRBlue think it might be worth try but as they are pitted am not sure if it will work , will look better than they do at the mo tho Thumbs Up
@ Googsy , yet again might be worth a try but as said above not sure if it is going to cure the problem but willing to give it a go. Thumbs Up
@ E4 GUY , I think you are right in that they could be improved , I do have some autosol buried somewhere ( got loads of tools and stuff like autosol but clueless and being disabled is a big disadvantage as it normally means paying someone to do something I would love to do myself but I know that after doing so I will be in agony , hey ho such is life Big Cry
But as you say I to like Eugenes idea , just a case of finding someone who can fabricate something like that as that would make them look like new. Thumbs Up
I spoke to Dan @ Duckworths and apparently the tips are not removable but part of the back box and when he told me the price of a new back box ( bearing in mind I was thinking about getting like others on here the back box painted ) I nearly had another heart attack, so that is not an option with horrendous pending vet bill :bulb:
Thanks for the ideas guys Thumbs Up
Cheers
Post #261988 28th May 2014 9:33pm
ebajema
Hi Dave, I remember that you are suffering from some pretty bad back issues so I understand that long times underneath the car are a problem. It is an option to lie on a rollerbed, the type mechanics use when working on a car in the old days before the hydraulic lifts became popular ??
You would need to protect your face, especially your eyes quite well though, working with chemicals and abrasives.
The suggestions of the other guys are a good start I'd say while trying to find a fitting piece of tubing.
For the polishing, if you have a little Dremel tool with some polishing discs, you don't have to do a lot of hard work that could affect your back. Especially if you don't have to do it underneath the car.
If that doesn't work, making the outside of the pitted tips smooth and straight and clean them (for the loctite to bond) needs to be done anyway. Note that stainless steel used to need Loctite Activator as well. The tips don't get very hot, relative to the rest of the exhaust and high temp Loctite can take up to 175 C. It is incredibly strong on a part that sees virtually no load, so you may want to use it sparingly so you can replace the tips.
The trick is to find stainless tube with the correct internal diameter so it fits snuggly over the old tips. That way you don't have to do too much extra work. You may have to buy a length of tube somewhere unless you have friends working in the metalworking industry that have short offcuts lying around. Maybe worth even calling a bespoke exhaust firm and ask them for offcuts.
Lastly, you may also just go to the car shops (Halfrauds and the likes) and look for cheap stainless tips there. You never know what you might find for a few quid that will last you a while. You know the likes that are added to the boy racer cars. I reckon if you find one that fits snuggly around the old tips you may have a winner for virtually no money Smile
You can also try and regularly cover the tips with wax (the same you use for the paint work) as that usually slows down corrosion a lot.
Stainless still corrodes, just a lot slower. The higher the quality (and depending on the type of stainless as there is a wide range with different resistance to the various types of corrosion) the better it resists corrosion but also the more expensive it gets. Anyway, some food for thought.
Lastly, you could try a bespoke exhaust type company and ask them if they can make you two new tips for not too much money. If you have a place with nice people working, they will undoubtedly do so if they have time. MY 2010 5.0 SC Galway green and sand interior!!
Post #261992 28th May 2014 10:31pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
There was another thread recently on this I believe. Someone came up with reasonably priced OE exhaust tips.
Mine have been super maintained since new. I polish them maybe twice a year, takes me 10 minutes.
Post #261997 28th May 2014 10:42pm
Muttley
Hey ebajema
I have to say I am amazed how how much effort you have put into your last post and all I can say is a huge thank you Thumbs Up
You have to laugh , I brought this I don't know how many years ago ( allways wanted one ) and you can maybe see its still sealed Embarassed , but its that saying " I will use that one day " Rolling with laughter
You really have given me some food for thought with your last post ( I know I am going on but hey I am so impressed with the amount of thought that has gone into your post ) Bow down Bow down Bow down
But and its a big but the amount of pain I suffer with my back , even with the extremely heavy duty slow release opiates I take among i don't know how many different pain medications I don't think I would stand a chance on one of those roller beds , as much as I would love to do it myself I know the amount of pain I will suffer as a result of trying to take on something like this Big Cry
A couple of days after buying the car I managed to flatten the battery , now most peeps would find the best price and fit said battery themselves , noooo not me , the only way round it for me was to pay top Halfords price for the Bosch S5 I think it was, this is purely because I knew they could fit it , little did I know how hard it was going to be for them to fit it but hey this is just one of the joys of life ( just in case someone decides to think along the lines that I am feeling sorry for myself and there is always someone worse off out there I don't do feeling sorry for myself ) It is what it is and you just have to get on with it Razz
But I really do like the sound of having some stainless tubes put over the old ones because ( now I may be wrong ) it would make them look like new and I think this is the way I am going to go , thats if I can find a company that can do what I want without costing me a fortune I haven't got.
I have looked in Halfords for tips but all the ones I have seen are just to short or boy racer and there is a fair amount of pipe on those tips.
And hopefully get my very friendly mechanic to paint the back box as after seeing the results of other peoples efforts I think this would look good Thumbs Up
Many Thanks
Cheers
Post #262007 29th May 2014 12:42am
ebajema
Hahahahaha, you are like me, my Dremel was lying around forever before I used it the first time.
Good luck with finding nice tips and getting the box painted. Am keen to see how things turn out !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #262015 29th May 2014 3:40am
mzplcg
Custom Chrome of Nuneaton made me several exhaust parts including a full custom stainless system. If you tell them what you want they will make it and they even have a rolling machine to flare the end so it looks like factory fit. It will also come polished to a mirror finish. Thumbs Up
Post #262016 29th May 2014 4:29am
Ranging from the acceptable to the ghastly here http://www.rockshore.uk.com/exhaust-tips-147-c.asp 2008 MY Supercharged
Post #262018 29th May 2014 5:11am
Dave,
Those tips are very salvagable. I have polished many an exhaust tip and they are not the worst I have seen.
All of the hints and tips on here are what I would do, Mr Muscle oven cleaner, degreaser and a few goes with Autosol. You'd be amazed how much comes back.
Having said that, when I bough the SC the tips were actually corroded and had clearly not been polished once in the car's 40,000 miles and 3 yrs of life. I asked the dealer to replace the tips and they said it wasn't possible without replacing the entire back box, which they did! Very Happy
If you were nearer, I would come and do it for you, just cos I love seeing the results! Thumbs Up Discovery 4 HSE
Post #262037 29th May 2014 7:30am
E4 GUY
+1
Amazon sell the #oooo ultra fine steel wool for £6 . Get a new tube of Autosol.
Take stuff down to one of those drive in car wash places and I reckon for a price they would do them for you. ?
You haven't got any young lads as neighbours you could ask? Do kids still go knocking on doors to wash cars at weekends? That's how i earned cash as a youngster..
Probably not ... Alcohol and eBay is never a good mix
Post #262043 29th May 2014 7:44am
