Home > Maintenance & Mods (L322) > Rear Shock Absorbers Td6
RF10
Switzerland 2006 Range Rover Vogue Td6 Zermatt Silver
Hi,
I have just had the front air struts changed with Delphi replacements on my Td6 after 86,000 miles. There is a marked improvement in ride quality but I can feel the rear shock absorbers are also getting close to their end of life.
What should I replace them with?
I have found replacements from Delphi, Monroe, Bilstein (I believe this is the OEM manufacturer).
Any experiences from the forum to share?
The genuine LR rear shocks are >£200 a side...
Thanks
Post #261391 25th May 2014 6:35pm
My experience of Monroe shocks are they are crap, bought 4 and took them off after two weeks replacing them with Bilstein which were great...This was on my Classic RR
Post #261412 25th May 2014 11:10pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I just had the same, replaced front struts and thought I would do the crusty looking and tired rears (103k miles).
Options on mine range from around £35 Monroe inserts to OEM Bilsteins for £85 (mines a 4.4).
Bear in mind that cheap Monroes I think are just inserts so need to rebuild the strut. Bilsteins are complete struts ready to bolt in. I went for Bilsteins, yet to fit them but quality looks good as you would expect for OEM.
Post #261449 26th May 2014 9:47am
Bilstein or why not Delphi? Thats who made the fronts you have just fitted!!! Match all four corners... Thumbs Up
Post #261463 26th May 2014 10:37am
