Home > For Sale & Wanted > [Wanted] Analogue Tuner
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
A1GSS wrote:
Is there still analogue TV transmissions then?
Not in the UK to the best of my knowledge. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #260875 22nd May 2014 8:44am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
@A1gss No analogue here anymore.
I'm changing cause I don't want blank space in boot but more importantly I think (from reading online) I need it for the MOST loop. So basically if one thing is disconnected other things eg Bluetooth, radio won't work.
@B9er pm sent Thumbs Up
Post #260876 22nd May 2014 8:50am
Googsy
Is this easy to connect up Lolo as I have HSE 2008 with loads of spaces in boot Thumbs Up did you need to run cable or are they already there? Thanks. Embarassed just read back and saw you had tuner fitted already .. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #261968 28th May 2014 7:56pm
Lolo
@googsy yep mine already had a tuner.. But there is no point in u getting a tuner it won't work here.. I just installed the analogue one today which was a nightmare getting access as its location has also changed from previous model years, So I have a digital tuner now to sell, just want to give it a day or two make sure all is well with the new one.. Thumbs Up
Post #261983 28th May 2014 9:15pm
