![]() | Home > In Car Electronics (L322) > Reversing camera |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 ![]() ![]() ![]() |
Mounted upside down? There's normally a switch or suchlike that you can use to flip the image - not sure if you can get that on reverse cameras? |
"The design of a backup camera is distinct from other cameras in that the image is horizontally flipped so that the output is a mirror image. This is necessary because the camera and the driver face opposite directions, and without it, the camera's right would be on the driver's left and vice versa. A mirrored image makes the orientation of the display consistent with the physical mirrors installed on the vehicle."
