Home > LPG > LPG fuel gauge confusion
Knightrider
Hi my ffrr has a romano system installed with the fuel gauge pictured below. I am a little confused as I thought that when the red led above the R lights up it meant the LPG tank was empty and the car has switched to petrol. Somebody has now told me that the red led means there is still LPG in the system and it's running on LPG not petrol.
Can anyone shed light on this?
 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #259718 16th May 2014 1:17pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Doesn't the "R" mean RESERVE? i.e. it is running on LPG but it's very low.
And then which fuel you are running on depends on the light at the bottom:-
Bottom Left = G (Gas)
Bottom Right = Petrol
So when it's cold it should start on petrol and then switch over to "G" as it warms up.
That's how I would interpret it........ 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #259719 16th May 2014 1:34pm
dingg1
SKOT is correct
Post #259764 16th May 2014 5:15pm
mjdronfield
Not got LPG, but I'd too go with Skot, R stands for Reserve I'd imagine. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259766 16th May 2014 5:30pm
Knightrider
Thanks for the replies yeh I guess that makes sense. I think the red light is not such a great idea as it implies tank empty, much better would be to keep that light as green so there were 5 green lights. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #259815 16th May 2014 9:07pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Got a stag 4000 system on mine, row of 4 green lights but the last one turns red when LPG level in tank is low.
Still OK to drive though, when it gets towards the 'empty' point it starts beeping at me, and if I continue to drive, switches over to petrol until LPG tank has been filled.
Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #259823 16th May 2014 9:44pm
dingg1
the indicators are way off IME (can be expected with a float in a toroidal horizontal tank)
I get lots of miles out of mine once it goes on to the red , it'll trip back onto petrol at a low pressure detected on the reducer anyway, nothing to be concerned about , just think about refilling once into the red and you'll be ok.
Post #259824 16th May 2014 9:47pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Just to make the confusion complete;
Mine has a BRG and if she runs on petrol the red light is burning. After a while, when the engine is warm enough, she will show 1 to 4 green lights, when she switches over to lpg.
Post #259879 17th May 2014 8:19am
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
I have a OMVL system on my Bimmer with the same gauge...
R is reserve...once it switches back to petrol when the LPG is empty it will beep at you continuously and the lamp will flash...cancel beeping by pressing the changeover button to switch to petrol permanently...then fill up with LPG and press the button to put it back to changeover mode.
Post #260040 18th May 2014 10:31am
