Home > LPG > Where do you mount your EAS Compressor
Discotigger
Saw this neat mounting kit for the EAS compressor if you've had the LPG conversion done, but don't know what to do with the compressor. Link below:
http://www.tinleytech.co.uk/acatalog/Range...UMP_2dL322
Thought it may be useful for you gas guzzlers Thumbs Up
Post #259479 15th May 2014 6:45am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
mounted mine with one of those mounting brackets(not that one but the same thing)
very good but i did insulate the tow bar stowage area first for extra sound proofing
also made a lid out of MDF to fit the stowage hole
make sure your boot seal is ok because it will soak up and hold any water
been there done that !!
Post #259491 15th May 2014 8:05am
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
I have the Preston air bracket kit if you need it! I bought it for mine but never got round to fitting it and have now sold the rangy
Post #327755 13th May 2015 5:42pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Mounted in the tow bar storage area with the cradle in the advert. Perfect !
Post #327788 13th May 2015 7:41pm
