Home > General > Scary Mileage?
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Scary Mileage?
Hi all
As you may know im looking for a L322 Diesel.. Provided you have good history, what mileage would you guys be happy to pay £8k-£10k on? I appreciate they go on for miles (my old P38's had 180k on with little issues)
Everything i see is around the 100k-120k miles mark with good history. Doesnt that scare anyone Shocked ? Theres quite a few out there for £8-£10k with 165+ thousand on too!Or are we confident that the L322 D is good for a journey to the moon and back if looked after before the big bits start falling off!!!
Thanks again
Tel
Post #259106 13th May 2014 6:24am
mjdronfield
To my mind, the diesel BMW unit is the most reliable unit fitted to the L322. They are well proven across the BMW models as well, though thankfully it doesn't have the dreaded swirl flaps fitted in the rr. Main reason I chose it over a petrol. Less to go wrong - some may argue, prob whilst leaning against a petrol pump.
Mines at 126k and uses no oil or water.
Those working on them on a daily basis will know more.......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259113 13th May 2014 6:56am
TD6 is very reliable but the GM box is more likely to need a rebuild post 120k.
Post #259116 13th May 2014 7:11am
It is not the engine that is the problem. Worry more about the rest of the running gear:
Gearbox
Air Suspension inc struts, bags, compressor, reservoir, sensors
All bushes front and rear suspension (inc subframe bushes)
Brake Calipers
Steering rack
Hub bearings
Probably in that order too. .
Post #259227 13th May 2014 3:07pm
Boydonegood
Awesome guys. Thank you! Least I know if it's got plenty history 130k+ ain't the end of her life!
Post #259229 13th May 2014 3:15pm
Big mileage doesn't necessarilly equate to unreliability, lack of maintenance does Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #259242 13th May 2014 4:38pm
mjdronfield
Or this theory ;
........if it's gone that far, there can't be that much wrong with it......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259243 13th May 2014 4:42pm
Or it should have already been replaced by that time! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #259245 13th May 2014 4:54pm
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
Re: Scary Mileage?
I've only had my '03 L322 for 4 months and clocked up 5,000 odd miles in her to date...but I must add I drive the living daylights out of it..both on its own and with a trailer. The BMW M57 is an excellent unit and good for hundreds of thousands of miles. The GM transmission is actually pretty decent....it's the torque converter that isn't man enough for the job. The air suspension, calipers, suspension bushes, electronics etc are wear and tear items....no better or worse than any other German car I ever owned. I actually rate these cars as pretty tough...but it is important to have a good independent workshop who these cars inside out and can keep them performing without charging the heart out of you. 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #259830 16th May 2014 10:20pm
Flashman
They are solid cars and as long as you look after them they will last you a lifetime.
Mine has done nearly 137k and is having its gearbox done for the 1st time. Engine is as smooth as when new. As long as you keep the oil changed and service the gearbox every 40k miles you should be easily able to hit the 200k and beyond. When buying at around the £10k level with a full history they are incredibly good value for money. Tom
Current Drive
Previous Drives
Post #259885 17th May 2014 8:58am
Boydonegood
Thanks guys for all the input.
Has kind of put any worries of 140-150k miles out of my mind as long as they come with good history.
Thank you!
Tel
Post #259889 17th May 2014 9:31am
theanswers
Ireland
Just checked mine there. She's on 181,000 miles.
Going Strong.
Post #260717 21st May 2014 3:34pm
alexoconner
United States 2011 Range Rover Supercharged 5.0 SC V8 Santorini Black
Mine 2011 has 128,000 and still going strong. No issues at all, as long as the maintenance has been done thoroughly it should be fine. But suspension is a thing to worry about. Current Cars -
2011 Range Rover Supercharged (mine)
2014 Mercedes GL-550 (wife's)
2014 Jaguar F-Type R (mine)
2012 Mercedes CLS63 (wife's)
2009 GMC Yukon Denali (shared)
2010 Land Rover LR2 (daughter's)
1994 Chevrolet S-10 custom drag racing truck (9 sec 1/4 mile; fast as hell)
2012 Lexus RX350 (wife's)
Post #260806 21st May 2014 10:40pm
oop north
Sorry to butt in on someone else's thread: Is there a scary big service bill at any particular point? I know on th discovery there is a big service at 105k miles - is it the same on tdv8?
I haven't seen any posts on this so sorry if there are thousands and I have not looked properly!
Post #261163 24th May 2014 7:38am
TugRR
^ Answering the above . . . yes & no !
All FF's upto I believe 2010 ( please correct if wrong ! ) have a BMW style service schedule.
In reality, this is on a cycle of : Oil / Inspection 1 / Oil / Inspection 2 and so on. So in theory, Inpection 2 is the big one but of course something pretty substantial may need replacement in between - ie suspension air bags & bushes. These are also service items in the real world . . .
There are other service jobs at time / mileage intervals eg coolant & gearbox (dependant on type), along with transfer and diff oils.
If you're asking the question it appears you value a service history. I've found routine service costs are not at all bad given the nature if the car. That being said I've always taken mine to an excellent independant and not a main dealer.
In summary, it's not the servicing that will catch you out, it's the unknown items - hope this helps
Thumbs Up Where do you go after one of these . . . ?
Post #261168 24th May 2014 8:21am
