Home > Maintenance & Mods (L322) > Anyone tried these? Led Fog Lights
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
These look v similar to the ones stan has. Anyone have them? Do u think they just plug and play ?
Powerful do some similar ones that are plug and play also
eBay Item No. 331094248727
Post #259065 12th May 2014 7:38pm
paulmoron2 has them,
http://www.fullfatrr.com/forum/topic23578-45.html ... - .- -.
Post #259070 12th May 2014 7:42pm
paulmoran2 ! Laughing .
Post #259072 12th May 2014 7:44pm
Embarassed sorry paul... Wink ... - .- -.
Post #259075 12th May 2014 7:48pm
Highly rated by cannabis growers Laughing Laughing
Post #259076 12th May 2014 8:10pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Lolo..I have Pm'd you with some info Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #259082 12th May 2014 8:31pm
I have loads of sets of these if anyone is interested? Im away from tomorrow morning for 10 days though...
Post #259088 12th May 2014 8:49pm
Mike.Boro
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I fitted these to my 2002/2010 conversion. Had to fit H11 resistors. They are the correct size and brackets are right, look the part. 10 mins to fit Thumbs Up
After I fitted them I think I seen on here Craig has them without the resistors, I think Confused
Post #259101 13th May 2014 12:32am
paulmoran2
Yes, if your using them in lieu of standard bulb fogs, the canbus (bulb failure) warning would appear on your instrument cluster display unless you switch off hot and cold monitoring using an IID tool ( or similar ) or have a ballast resister in place.
In my case, I terminated the fog positive and negative feeds and just powered them off the DRL switch, then turned hot and cold monitoring off ( thanks Stan for that advice)
No warnings Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #259126 13th May 2014 7:49am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Has anyone tried putting these fogs onto a <2010 model? If they are the same size as the pre-facelift they should work no?
Post #298371 11th Dec 2014 2:41pm
i have these, produced by craig [cam-tec]
Post #298372 11th Dec 2014 2:48pm
paulmoran2
Horse86.
AFAIK The pre 2010 are different to the 2010+.
As Stan has said, one of the site sponsors ( Cam-tech) is able to supply plug and play LED fog light for pre 2010 that he has engineered.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #298376 11th Dec 2014 3:14pm
horse86
Thanks Stan and Paul. Very cool. Those look a lot like the ones for the 2010+.
Is the glass clear or fluted? So no errors? Strictly plug and play...or do you have to wore in resistors? I don't really want to mess with tapping into the wiring and adding resistors unless they are the ones pre-wired with sockets so it's plug and play.
Do they operate as the stock fogs or are they DRLs? How is the output...more for looks and not as bright as stock? Are they CREE LEDs?
how much did they run you?
Post #298380 11th Dec 2014 3:41pm
http://www.fullfatrr.com/forum/topic22046....fog+lights
as for price, you'll have to speak to craig re that.. ... - .- -.
Post #298396 11th Dec 2014 4:49pm
horse86
thanks for the link!
Post #298413 11th Dec 2014 6:08pm
