Home > Maintenance & Mods (L322) > over kill on interior lights
i had some of these leds which cost a quid each so i put two of them into the front interior light which normally has only one small bulb,
the light unit was dismantled and these leds were stuck with on with 3d tape on each side of the normal bulb hole..
they certainly brighten up the interior when on... ... - .- -.
Post #258834 11th May 2014 8:40pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I take it you often drop change down the seats at night? Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #258840 11th May 2014 8:45pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I did the same Thumbs Up
Post #258850 11th May 2014 8:59pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
They look bright Stan are they good 1994 softail full stars n stripes custom harley davidson
Post #258865 11th May 2014 9:35pm
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Look smart Thumbs Up
Post #258868 11th May 2014 10:04pm
these are very bright, maybe a bit to much but that is the case ill just remove one led square..
@lolo, did you use the same leds? ... - .- -.
Post #258884 12th May 2014 6:18am
Welshdragon
They do look very bright Thumbs Up
But whats your dash cam? You have changed it from the cheapy on I see Mr. Green Thumbs Up If it dont work.......burn it!
Post #258886 12th May 2014 6:45am
re dashcam, cheapy one now on left side of mirror , recording at 720p and feeding live video to the rse, new £20 jobby on right of mirror recording at 1080p... ... - .- -.
Post #258887 12th May 2014 7:00am
Welshdragon
You could move the 720 to the rear now then Thumbs Up If it dont work.......burn it!
Post #258899 12th May 2014 7:43am
thought of that but wife says rear passengers would like to see whats ahead on the rse screens....makes sense but i will move it to the back later, i'm sure she wont notice .. Cool ... - .- -.
Post #258900 12th May 2014 7:45am
n1cktdv8
I did something similar and then went down to 1x LED tbh. Like you already say Stan, I found it a little too bright and with the other LED's all around the cabin now providing good lighting I just got a bit carried away ! Is this where I put the car details and a bit about myself ?........
Post #258906 12th May 2014 8:15am
i had the one led in there [like you] until it started to flicker so being ubra bored and trying to find a use for these leds i had lying around, the executive decision was made to fit them into the light unit..
i guess they will be more appreciated when the early dark evenings come along.... ... - .- -.
Post #258911 12th May 2014 8:32am
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
can you remember where you got those leds from stan? might try some at a quid
Post #259023 12th May 2014 5:10pm
Lolo
Ebay have them, put in dome LEDs in the search Thumbs Up
Post #259029 12th May 2014 5:54pm
@clarkie, i got 10 for a tenner but i found these if you can wait for the delivery ...
http://www.ebay.co.uk/itm/10x-White-5630-S...258e60b1f5
Post #259047 12th May 2014 6:28pm
