Home > eBay & Bargain Spots > Aldi compressor
I bought one of these a couple of years back and it's been fine for little jobs, it uses different connectors to the airtools from Machine mart, and I found it lacks a bit of power, but for general stuff, air gun, ratchet, sockets etc, its fine. It can get noisy when its filling up, and even though it has a rubber foot the vibrations means it moves around until it reaches the end of it's power cord! Discovery 4 HSE
Post #258640 10th May 2014 7:23pm
2 Tonne trolley jack is right on the limit for the FFRR, best go for 3 tonne capacity.
I bought one of the Costco aluminium trolley jacks, they are rated at 2 tonnes, but that is American measurements so in reality it is a 1.8 ton lift and although it will lift the FFRR it really is a bit of a struggle and not something I would recommend
I also have a 20 tonne bottle jack which came out of my Scania when I was in the haulage, not much it doesn't put in the air but the lifting height is the limiting factor,
My 50 year old Epco 3 tonne trolley jack is the most used for the FFRR as it will lift the FFRR clean off the ground without any problem.
Don't forget to use good quality axle stands once you have the vehicle raised, again the cheap ones are not up to the weight of the FFRR. I opted for a pair of Draper 12 tonne stands which are tall enough to fit under the back chassis therefore you don't have to worry about the stands sliding off the rear suspension.
If you're lucky enough to have a 4 post ramp in your garage you could always go for a air operated jacking beam, they have all the built in safety features and are perfect for working on suspension areas under the FFRR
Hence the Hydrovane compressor
Post #258650 10th May 2014 7:59pm
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Compressor
Hi all,much to my disappointment aldi no longer have the compressor that I would like.
I have found this one on the bay of flea and was wondering if it would be sufficient for my garage at home.
http://www.ebay.co.uk/itm/Rhyas-50L-Litre-...51a90867fd
i want to change wheels,chisel walls and other tasks both on my car and in the home.
I would be greatful for some input regarding the above.i don't want to find that I am under compressed in the future.
Regards tony [/list]
Post #259262 13th May 2014 7:20pm
Not big enough, it will run out of air and you will need to wait on it filling up every few minutes
Post #259301 13th May 2014 10:18pm
Single phase - standard supply for domestic and light industry 220/240 volts.
5 amp light circuit - not suitable for equipment
13 amp ring main - max 2.5 hp std compressor, max 3.0 hp for LC compressors
45 amp cooker/shower - max 3.5 hp compressor
Single-phase compressors up to 2.5 hp can operate from a 240v 13 amp power supply, with the exception of the new 3 hp low current models. 3.0 hp and above must operate from a 240v 30 amp supply. Wherever possible, choose a larger compressor than you require at present to allow for expansion. Compressors with cast iron cylinders running slow offer a much extended service life.
a 3hp compressor will give you around 14CFM of air and should be enough for most of your requirements but note that you will need to run a heavy cable from the consumer unit as it requires a 30 amp circuit
Post #259306 13th May 2014 10:32pm
