Home > Technical (L322) > windscreen trim clips
g1968g
Hi,
the trim on the drivers side is loose and wont clip back into place properly.
Whats the bet fix for this.
Does the trim just pull off, i haven't forced it incase i break something.
Cheers
Geoff
Post #255180 19th Apr 2014 7:51pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
if you are talking about the vertical black trim then it it clipped in place and then there are 3 (?) plastic rivets on the rear edge on the door side. You can get a replacement clip set from LR to re attach the panel as it needs to come off for a windscreen replacement. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #255210 19th Apr 2014 11:33pm
mjdronfield
If it's the a pillar trim, I got some more clips for mine, but when garage man was replacing them, the receiving bits in the body itself dropped down the structure or moved, so the rivets are loose. Trim seems fine though........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #255225 20th Apr 2014 6:45am
