Home > Maintenance & Mods (L322) > quad hid xenon headlights
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
@Adrian. My car does have the bixenon hid lights as standard, thus do have head lamp washers. What i have done is to put hids in the high beams (brights) and foglamps.
I am still looking at the possibility of making the high beam bi-xenon (a combination of the main (dim) and high beams)
Post #262696 2nd Jun 2014 4:01am
ebajema
QUOTE
Thanks for all your great comments. As to the knocking yep it's there, the pockets in the back doors are for newspapers as the dealer says, that's about all they are good for. The screens are 10.2 inch standard on this car. The led's are spot lights, supplied by mike, a sponcer on d3 forum. They are ridged industry's 6inchSR2 hyper spot.
UNQUOTE
Above comes from another post http://www.fullfatrr.com/forum/topic24321.html
I knew that is where I saw it once I bumped into that post today Smile It's on page 2. MY 2010 5.0 SC Galway green and sand interior!!
Post #263094 4th Jun 2014 4:21am
vnitos
how to connect high beams
I'm in the process of converting my lights to quad bi-xenons. I got the projectors for the high beams that works similar to the factory fitted bi-xenons together with the hid kit.
question is now- what must i do to enable the high beams to come on together with the low beams if want the lights to be on low beam
Post #266808 23rd Jun 2014 6:33am
use a multimeter on the headlight socket to find the dip beam feed and wire to your main via a relay...
edit...the headlight feed on my 2008 is the yellow/green wire. ... - .- -.
Post #266809 23rd Jun 2014 6:34am
vnitos
thanks Stan
Post #266901 23rd Jun 2014 12:46pm
vnitos
need some more help - I've connected the new bi-xenons but only get the dipped beams to work by splicing into the green/yellow wire as suggested by Stan - now not sure which one is the one for the main (high) beams that goes to the original bi-xenons
will appreciate if someone could advice as to the colour of the wire
thanx
Post #267421 26th Jun 2014 8:06am
vnitos
success at last - quad xenon hid headlights fitted and working - will post photos later
Post #267462 26th Jun 2014 1:36pm
ebajema
Cool Bow down Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #267465 26th Jun 2014 2:09pm
vnitos
photos of quad xenon lights
high beams & fog lights
dipped beams
high beams
Post #267502 26th Jun 2014 4:21pm
