Home > Technical (L322) > Redish watery and oily leak |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I think the transmission oil cooler is across the centre underneath the main rad. It could be coming from that, there is a pipe entering from both sides. That said a proper oil or transmission leak would be mostly oil with little or no water as it would form a creamy slime...
18th Apr 2014 8:59pm |
Wookie Member Since: 26 Mar 2014 Location: Bournemouth Posts: 14 |
Removed the underbody it appears leak is coming from the hose connection on the small rad on the left (looking from the front) I've squeezed the hose and it makes the antifreeze coolant in the expansion filler bottle move. So I presume the small rad is also water coolant ? |
19th Apr 2014 7:25pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
Yes it secondary rad
20th Apr 2014 8:14am |
