Home > Technical (L322) > Pressure build up in cooling system |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 |
Having a bad week, bought a Triumph Stag, drove all the way home from Stoke with no real problems (280 miles), took my mum out for a spin round the block and blew the head gasket.......up to my neck in oily bits at the moment.
7th Jul 2010 10:51pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
Check the water pump. The OEM one has plastic fins so if the bearing goes, all of the fins disintegrate and the pump becomes ineffective. Mine added the bonus of throwing the belts off.
8th Jul 2010 7:15am |
If you get no heat from the heater then that sounds very much like an air lock. Too much air in the system will enable the coolant to expand/boil which will then compound the issue and then cause your over-pressurization issue.
8th Jul 2010 8:33am |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
I've been thinking about replacing the rad for piece of mind myself when the car is next in for a service, any idea how much they are?. |
8th Jul 2010 10:36am |
£160-£200 http://www.island-4x4.co.uk/-c-144_2408.html |
8th Jul 2010 10:38am |
Thanks for that Dan, much appreciated , the car has been fine since I've had it but am thinking a rad change and gearbox oil change might be a good idea next time I get it serviced, prevention being better than cure and all that. |
8th Jul 2010 10:47am |
Mine was genuine, £120.
8th Jul 2010 12:39pm |
Thanks for all the input guys, just got it back with new top hose and new thermostat. Mechanic seemed pretty happy with it. Heater blowing really strong with hot air although aircon not blowing anywhere near as cold as it was the other day. Also centre dash vents only blow cold when wheel turned to 3 blue dots, any other position it's hot air even with temp dials turned all the way to minimum...confusing!
8th Jul 2010 6:40pm |
