Home > Technical (L322) > PDC - agin
comports
PDC - agin
Hi Folks,
So had a search on the forum and can't find the answer (I don't think)
PDC is playing up and getting the constant tone and flashing light on the console. IID tells me "front centre right" has a fault but it clicks fine when I listen to it..?
Is it still likely to be an issue with that sensor..? Can I just unplug that one and use the rest for the time being..?
Thanks Ash
2016 SDV8 AB
Post #254428 14th Apr 2014 5:41pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Okay first answer is no you can't just unplug and use the remainder the PDC ecu will inhibit the entire system until it is fixed secondly I wasn't aware that each sensor could be interrogated separately on the front or back.
Try swapping the sensor to another connector and test again if the fault moves it is the sensor if it stays the same it is wiring or ecu 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #254430 14th Apr 2014 5:50pm
comports
Thanks Steve,
I was going by the readout on screen from the Intravee II... Tells me the distance to each sensor and they all look good.
IID tells me there is a fault with front right centre so a bit confused.
Will try the swap first
Thanks Ash
2016 SDV8 AB
Post #254431 14th Apr 2014 5:56pm
