Home > Wheels & Tyres > Tyre monitor system fault
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Well i got 4 new tyres fitted and put 4 new tpms sensors on. They were registered automatically ok after about 15 mins as they're supposed to. Everything fine I thought. Then today while driving along I get a "Tyre Monitoring System Fault" message and the amber tyre symbol flashing. Has anyone had this? It was operating pretty reliably for me previously but I changed them since the batteries in the originals were nearing end of life.
Tried battery disconnect but error is still there Big Cry Any suggestions what can cause this? 2007 TDV8 Vogue SE Java Black
Post #250395 25th Mar 2014 9:22am
i found this during a forum search, could give you and idea where to look,
i found my system showing errors all the time so i switched it all off with an iidtool.. ... - .- -.
Post #250397 25th Mar 2014 9:30am
taskam
Thanks Stan, I did see this and also in the shop manual it says this error comes up if more than one tyre sensor fails. Seems hard to believe this happened simultaneously. I can see why disabling this system seems the best way forward given the pain this system causes.... 2007 TDV8 Vogue SE Java Black
Post #250400 25th Mar 2014 9:46am
taskam
...and now it's cleared itself Rolling Eyes 2007 TDV8 Vogue SE Java Black
Post #250495 25th Mar 2014 4:35pm
RR2008HSE
I'm with Stan. IID and turn it off in the CCF.
It's not hard. Even I managed to do it! (With nice step-by-step instructions from the IID folks.)
Post #250571 25th Mar 2014 8:39pm
Mine randomly came on & off for years - switched off with the IID now Thumbs Up
Post #250575 25th Mar 2014 8:46pm
taskam
Agreed........I'll be getting iid tool sometime soon. 2007 TDV8 Vogue SE Java Black
Post #250594 25th Mar 2014 9:39pm
Andy B
Hi Alistair, can you remember what menu you need on the IID to turn off TPMS monitoring? Got the standard TPMS System Fault and want to turn it off.
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #287996 21st Oct 2014 6:03pm
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I thought mine had sorted themselves out as were working perfectly for a month or so. Then hit a pot hole last week and I'm back to constant amber lights. Anyone near Sudbury Suffolk able to turn the bloody things off for me lol
Post #288018 21st Oct 2014 8:06pm
Sorry - can't remember, but it was pretty obvious - it's about the only thing I've done with my IID - it might even have been under TPMS Confused
Post #288024 21st Oct 2014 8:46pm
Andy B
Thanks Alistair, error message seems to have gone away this morning, but I still want to turn the Censored TPMS off so I'll dig around in the CCF this weekend.
Cheers,
Post #288067 22nd Oct 2014 7:38am
taskam
Same with mine. Goes off for a few days and then flags TPMS equipment failure for few days, and repeat. Still to get an IID tool and this will be the first thing I do. 2007 TDV8 Vogue SE Java Black
Post #288106 22nd Oct 2014 12:33pm
Andy B
It's a pain in the Censored If you get your IID, the setting in the CCF is in the BCM-Body Control sub menu SDV8 AB MY 2019
Post #288109 22nd Oct 2014 1:10pm
taskam
Thumbs Up 2007 TDV8 Vogue SE Java Black
Post #288138 22nd Oct 2014 5:44pm
