Home > Maintenance & Mods (L322) > 10 month old battery failure or something else? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Instruct them to change the battery under warranty and then see how it behaves over the proceeding week Even if it does not resolve the issue, a new battery has to be better than an 11month old one |
22nd Mar 2014 12:41pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
I'm sure they will love that request. To be fair it's the logical next step and I'm sure they can claim it back as the unit is still warrantied anyway.
22nd Mar 2014 12:44pm |
Exactly... |
22nd Mar 2014 12:46pm |
23rd Mar 2014 8:36pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Battery 2020 Porsche Panamera Turbo Hybrid (V FAST)
23rd Mar 2014 8:50pm |
If it's not locked it wi wait even longer before going to sleep.
23rd Mar 2014 10:46pm |
I think I get your point KP but this is a repeat issue with the car even when it has been on a good run, then gets parked in the garage, locked up and left overnight. The issue being the drained sounding anaemic start up. I'll take the advice of CTC and suggest that another new battery seems reasonable |
23rd Mar 2014 10:52pm |
Agreed I'd still take Craig's action but they still need to get to the bottom of the drain
23rd Mar 2014 11:33pm |
Following on from my post when I queried whether or not, despite no systems being switched on (e.g even auto light switch set to the off position, no radio on etc) could simply not locking the car lead to a battery drain from systems taking longer to shut down and going to sleep:
26th Mar 2014 5:14am |
If it's permanently live then it's possible but it would have to be a really poor one to drain that much power.
26th Mar 2014 5:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
the only live socket on yours Ryan is the rear one in the load area...did you check the obd port to see if its closed properly? ... - .- -.
26th Mar 2014 7:59am |
@KP - Phone adaptor light only comes on intermittently when engine running. Point to note though, it's a rubbish universal adaptor that I bought in Tesco and it doesn't work properly to charge the phone, coming on and off when it takes the notion (you've often got to hold on to the phone and the connector to keep them mated so as to get any charge!). So maybe there' an answer to the problem in this reply?
26th Mar 2014 8:22am |
thats the one Ryan. ... - .- -.
26th Mar 2014 8:25am |
To be honest I avoid the cheap chargers as they are lethal in the long run. Get a proper USB cable for your phone and a belkin USB car charger and jobs a good en FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Mar 2014 9:08am |
