![]() | Home > In Car Electronics (L322) > Ezidab Crackle |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Hi
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
The FM modulation method of listening seems to be a bit of a weak point, which is why I use the Aux input by
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
There are no cables above my house thankfully !! Alan I do not have the luxury of aux in I wish I did. I am very interested in your antenna grounding comment as this is something that I had not even considered. I am using Alpine KAE-5DA2 this is stuck onto the windscreen but had not fitting instructions could it need an earth ? Thanks Mick. |
That's the very same as the one I have and it certainly came with a copper foil that had a sticky side to it, which was stuck to the inside of the roof. It was rolled up and it would be quite easy to miss it. It's rolled up and had a which backing to cover the sticky side of the copper foil.
