Home > Technical (L322) > FBH - Temperature Adjustment |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
i've looked on the gap site , http://www.gap-diagnostic.com/products/iidtool.html and the iidtool only gives live values as far as i can see.. ... - .- -.
13th Mar 2014 4:37pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Andy
13th Mar 2014 8:02pm |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 |
Which Mike is that please? 2017 4.4 SDV8 Autobiography |
14th Mar 2014 8:35am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
14th Mar 2014 12:38pm |
IIRC the batteries were changed as part of this issue to gel type and the battery charging controls changed as well as the FBH timer cutback from 30 to 18-20mins. The cutback is going to cause more of a temprature issue as well not allowing it to get fully hot or the system getting warm and the thermostat opening up to the engine block and then it sucks all the heat out of the water mean while the interior fan is still running at decent power and just pushing out cooler air. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
14th Mar 2014 3:58pm |
Mine had the software updates done by LR, and the new gel battery and it works fine, no low battery warnings and never failed to start - yet!
14th Mar 2014 4:08pm |
Did you own the earlier model (3.6TDV8) for comparison? 2017 4.4 SDV8 Autobiography |
14th Mar 2014 4:10pm |
3.0, 3.6 and now the 4.4 V8 Diesels |
14th Mar 2014 4:15pm |
Iirc the main issues came from the 2010MY revision with the 3.6 tdv8 and sc but IMO I don't think the sc would be as badly affected due to it's lower drain when starting. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
14th Mar 2014 5:54pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
Hello awclymm
14th Mar 2014 6:51pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
My FBH has never worked properly and has always blown cold air even after replacement with a new unit. Dealer still trying to sort it out. |
14th Mar 2014 8:38pm |
It seems I've opened (re-opened?) a real can of worms here.
14th Mar 2014 9:01pm |
You only usually hear about the problematic vehicles on forums - unless your an enthusiast that's why the average person or new owner visits them |
14th Mar 2014 10:13pm |
Awclymm, the only difference with my 4.4 over my previous vehicles is that it runs for 20 mins rather than 30. But with my previous vehicles running at 30 caused flat batteries and starting issues so I am happy for it to run at 20 mins and give no issues
14th Mar 2014 10:17pm |
