![]() | Home > Technical (L322) > Tdv8 gearbox fault |
Could easily be the front diff as they are a little problematic... Rarely hear of transfer box issues... |
Cossie Member Since: 01 Mar 2014 Location: Edinburgh Posts: 7 ![]() ![]() ![]() |
Hi I've been told it's possibly the gearbox and transfer box. Won't no till stripped. Taking it to specialist auto transmission garage . They are looking at 4 k plus vat for recon box and new transfer box.is this a good price...... Landrover asking 8.5k!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
Easy way to check if you are getting drive from the box and transfer box, do the driveshafts still rotate in drive/creep when the car is going nowhere, if so then front or rear diff problem? There is nothing that can't be fixed with a hammer😜😜
Hi when you engage any gear inc reverse the grinding spins up quick and you can see the prop trying to turn from the transfer box but really don't wont to keep doing it for any length of time. The car won't hold in park either.getting a lot of mixed views from mechanics. Problem is it needs stripped to a degree to find out and whoever strips it has got me were they want.ie if I don't go with them I get the motor back with a box of bits and it's not an easy motor to transport about in this state.arrrg.. Would be great if it was a diff but the noise seems to be from the transfer box area as it's trying to turn the prop. No one local will touch it even a couple of landrover specialists. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
Thought about trying a ZF specialist - I believe they have some depots ?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
Mackie Transmissions in Glasgow are ZF specialists.
Hi that's were it's headed. They have a very good reputation but that comes at a price! Just over half of land rover though. Will keep you posted when I get it back. Thanks for help and advice
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The big giveaway is that the park lock won’t hold. On the 6HP26X the park lock gear is EB welded to the output shaft :
Makes sense basically what I've argued with the first garage. I'am not a mechanic but I no basics of drive train and general mechanics. You have to owning a rangerover!
Mackies do know their stuff and have an excellent reputation . 2008 MY Supercharged
Hi all. Just to keep you updated. Got the rangerover back today from mackies in Glasgow.
This seems to be the same failure posted by drivesafe (http://www.fullfatrr.com/forum/topic24438.html)?
You have a good point here. One word of warning though. There are no tell tail signs the car drove perfect until an almighty bang. Stock up on gearboxes etc and you be sure to sell them soon! My mileage is only 68k. Expected a bit better from such an expensive car new. Land rover are aware of the issue but won't broadcast it.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8414 ![]() ![]() ![]() |
Or did they not bother uprating this part when they stuck the V8 diesel engine in... is it because it can't take the torque?? Pete
