Home > Technical (L322) > Another FBH issue
Ozzy
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Another FBH issue
Hi All,
I've never noticed the fbh kick in on cold mornings so I finally got round to investigating. I plugged in the diagnostic tool to see what errors were logged but it couldn't talk to the fbh ecu. Checked the fuse, all good so next step was to check the connections to the fbh itself. Took the battery and tray out so I could see the connections and noticed the power connector wasn't plugged in and was tucked out of the way. Hmmm!
Plugged it back in and as soon as I reconnected the battery the fan on the fbh started running and carried on running. Connected the diagnostic tool back up and I can now talk to the ECU but no faults logged. Looked at some live data but the outside temp was too high for it to kick in but things like coolant temp looked like reasonable values. I'm guessing it still might have some kind of ECU issue? I've had to pull the fuse (59) to stop the fan running for now.
Is there anything else I should check before assuming an ECU issue?
I know there are lots of fuel burning heater threads on here already and I've looked through most of them but they don't seem to cover the problem I've got or maybe my search skills are lacking Embarassed
Post #245783 2nd Mar 2014 1:41pm
mjdronfield
I'd imagine that any previous faults could be saved if the power has been disconnected, but for how long, I'm not sure.
No new faults will be generated until they happen, so until it gets the right condition to fire up again, you may see nothing.
Not an expert in this area though....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #245792 2nd Mar 2014 2:27pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Suspect the power was removed cos you maybe have the duff resistor fault - causes the fan to run every time you
lock / unlock, open boot etc .....
Still waiting to fix mine but living with the fan running each time.
Post #245798 2nd Mar 2014 2:35pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Re: Another FBH issue
Unnecessary quote removed
have a look at this,
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
Post #245800 2nd Mar 2014 3:00pm
Excellent find ironhorse Thumbs Up .
Post #245821 2nd Mar 2014 4:28pm
ironhorse
have been using that site for a couple of years now for the odd FBH problem, look up french mike he is the guru he will always answer a PM
Post #245826 2nd Mar 2014 4:59pm
Ozzy
Thanks all for the replies. Thumbs Up
Thanks for the link to the thread Ironhorse. I'll have a read of that whilst I wait for the temperature to drop to see if it that's my only problem.
Post #245827 2nd Mar 2014 5:14pm
Ozzy
Whilst waiting for the temperature to drop enough for the FBH to start I plugged in the diagnostic tool again and found a function to force the FBH on for 3 minutes. Wish I'd spotted this earlier rather than waiting until it got cold again! Rolling Eyes
This time a fault code was logged "Air Combustion Fan Short Circuit to ground". I'm guessing this pretty much confirms an ECU issue. From reading the thread Ironhorse linked to it looks as though I can get the ECU out without removing the entire unit.
Post #246121 3rd Mar 2014 9:25pm
ironhorse
they are a tight fit on the full fat (under the battery tray) i accessed mine through the wheel arch,
1st have you tried removing fuse 59 for a couple of mins to reset and clear faults
and also have you tried bypassing the temp sensor to enable it to run at any temp
nige
Post #246168 4th Mar 2014 8:42am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
mine is coming up with glow plug flame detector when i scanned it ,is this the pcb board or the glow plug
Post #246236 4th Mar 2014 3:13pm
ironhorse
read this a few times
do the tests below
http://www.the75andztclub.co.uk/forum/show...stcount=27
remove it from car and do some proper tests
You can check the glowpin with a meter, it should measure 0.3 Ohms - which is below the usable range of most meters, so expect it to show a short. The unit measures the resistance of the glowpin to determine whether it is burning, if the resistance it measures proves to be too high, then it might apear to fire initially, but then shut down. FrenchMike suggests this theory can be tested by connencting a 12v 21w (stop lamp) in parallel with the glowpin. Basically connect the bulb across a pair of sewing needles so you can spear through the insulation to connect to the glowpin wires or connect between the output of the FET driver and ground. Then see if it will run normally.
An alternative way to check the glowpins operation, would be to measure the total current the entire FBH consumes. There should be a large sudden draw of current, when the glowpin is powered up which should be around 15 to 20amps and the easy way to measure it is by replacing the fuse #59 with a meter, but that will not confirm its resistance is within spec. also if you put 12v to glow-plug it should get white hot within a few seconds
and only when you have the facts you could PM mike for a second opinion on the PCB
nige
Post #246271 4th Mar 2014 4:43pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I stripped my fbh and put 12v across the glow plug for 1 second to confirm it was ok.
Fbh problems 9 out of 10 boils down to the pcb and it's the same two resistors every time.
Lots of Fbh units have been binned and only needed a few pence worth of resistors changed!
Post #246281 4th Mar 2014 5:52pm
Ozzy
I'm pleased to report that it is now fixed Very Happy
As recommend in the earlier replies I got in touch with FrenchMike (from the Rover 75 forum) and sent the PCB board to him. You can remove the PCB with the unit in situ (once the battery has been removed). He diagnosed a faulty capacitor and a resistor out of range. I received it back earlier this week and fitted it today. Forced the unit on with my diagnostic tool and checking the live data it appears to be working ok and no new faults logged Thumbs Up
I don't think it'll get much use now but it's good to know it should be ready for next winter.
Post #250788 26th Mar 2014 7:26pm
PaulB
Nice one. Thumbs Up
Mike's got a nice little thing going.
Post #250797 26th Mar 2014 8:06pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Could anyone PM me French Mike's details please? Thanks.
Post #250869 26th Mar 2014 11:35pm
