Home > Maintenance & Mods (L322) > Fitting New Facelift air con controls to 2003 Vogue
Page 1 of 3 123>
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I've bought a facelift 2007 air conditioning control unit to upgrade my air conditioning controls to the newer aluminium finish ones, which are much more attractive than the cheap black plastic ones which came as standard on my 2003 Vogue.
The unit in appearance looks identical to the 2003 model with exception the air con 'snowflake' button and the prog window defrost button have been swapped about; My query is can I switch the units over will it be plug in and play? or will I have to strip the unit down and swap the knobs over? I appreciate there's been a few posts on this in the past however I'm still not too sure what the best way to go about this would be Whistle
It would be ideal if I could just switch over the foundry fascia from my existing unit to and new one and plug it in (if possible)
New Unit
Existing Unit
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #242585 13th Feb 2014 10:45pm
RangeK1D
Canada 2004 Range Rover HSE 4.4 V8 Zambezi Silver
Hey Andy, is the unit a different color than what is currently attached to our RR's? The PowerfulUK fella has videos on removing this unit and so forth on YouTube, that might be of some use to ya. And as far as I know, I think the knobs being switched around would be easier wouldn't it? Zambezi Silver Range Rover (2010 Autobiography Facelift)
Mercedes Benz GL450 4Matic (X164)
Mercedes Benz E500 4Matic (W211) (Sold)
Mercedes Benz 300SDL (W126)
Lexus LX470 (J100)
Audi A8L (D3 Chassis)
Post #242594 13th Feb 2014 11:19pm
andy180
Yeah I've seen the video's on Powerful's website Thumbs Up I'm relatively comfortable removing the unit but to remove the knobs you have to strip the full thing down so wondering if I could just change the foundry fascia to my existing one and plug in and play the new unit.... would save sometime and fiddly job if it would be possible Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #242596 13th Feb 2014 11:24pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
plug and play, i did mine a couple of years ago and everything works as it should just in a different place. Thumbs Up
Post #242597 13th Feb 2014 11:25pm
dnbaker
United States 2004 Range Rover Westminster 4.4 V8 Bonatti Grey
Same here. I swapped mine with a used unit with the newer knobs and everything works perfectly - definitely plug & play. Huge improvement in looks as well. 2004 RR Westminster 4.4 V8
Bonatti Grey/Jet
Post #242606 14th Feb 2014 3:33am
RangeK1D
Gotcha Andy, well I think I might dab in this as well if I can find a well priced unit. Zambezi Silver Range Rover (2010 Autobiography Facelift)
Lexus LX470 (J100)
Post #242607 14th Feb 2014 4:17am
andy180
Thumbs Up Excellent news just what I wanted to hear Razz I'll hopefully get this done over the course of the weekend! Fingers crossed the one I've boughts working ok. Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #242625 14th Feb 2014 9:04am
andy180
I spent the morning trying to fit this. No issues generally except the unit I bought wasn't working so back to the drawing board Whistle
After much deliberation I decided to strip down my existing unit and use the front bit with all the buttons on my old 'electrics' which seems to work fine except Thumbs Up Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #243816 20th Feb 2014 12:43pm
Andy
Isn't the suspension raise/lower switch different on later models?
2010 one here if anyone's interested :
Genuine MY10 heater/climate control unit Range Rover Vogue L322 2010 - 2011 NEW
http://bit.ly/1mwOCcB
Post #243849 20th Feb 2014 3:48pm
SteveMFr
Site Sponsor
Yes, completely different. The height control switch is a rocker behind the terrain response knob
The knobs in the bottom panel of your auction piece are seat ventilation. I'm sure you could adapt one of the aluminum knobs to the older height control switch, but that would be a rather expensive knob...
If you are going to be adapting, how about this?
https://www.google.de/search?q=lr3+terrain...p;tbm=isch
or
http://www.ebay.ie/itm/3-PCS-Aluminum-Allo...3a7cda2eed
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #243963 21st Feb 2014 8:29am
andy180
Surely someone must know something about these units? I can't understand why the blower is no longer working Mad today I switched the boards over and fascia back to the original it's still not working even though it turns up and down with the max air con, auto and windscreen clear button Rolling Eyes
Could it be an issue with the unit? I can't see why... The physical mechanism is working as it should and it worked fine before I changes the fascia over. As I said above I tried fitting my old fascia back on and it's still not operational!
Help Please Big Cry Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #244092 21st Feb 2014 5:28pm
andy180
I've done a few videos.
This shows the mechanism is clearly working from the rear of the fascia, the white bit turning confirms that the mechanism is working as it should so it isn't an issue with the control knob as far as I can see.
&feature=youtu.be
As you can see it just isn't operating the fan, even though it works with various other buttons Big Cry
And even tried it with the old fascia and board, still nothing. I can't understand it doesn't seem to be a fan fault as it's working with other buttons
[URL=]
[/URL]
Post #244130 21st Feb 2014 7:50pm
Googsy
Exactly what happened to mine when I removed it the auto button when used manually just illuminates 3 lights and is stuck on auto.Did you get this sorted. I'm thinking looking at your videos maybe a battery reset is in order? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #249938 22nd Mar 2014 11:05pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Battery reset, check the diagnostics etc
When my battery last played up it knocked out the drivers door power completely, windows lock etc etc battery reset solved it in the end, the diagnostics couldn't do it but a battery reset did
Post #249943 22nd Mar 2014 11:25pm
andy180
I've not done a battery reset as such however I have had the battery disconnected to do a couple of other bits and it hasn't had any effect (I assume the re-set is just off and on?)..... I'll need to go down and see my mate who has the diagnostics kit
It's good to hear you had a similar issue and got it sorted Googsy Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #250003 23rd Mar 2014 11:33am
Page 1 of 3 123>
