Home > Technical (L322) > Wobble ... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
could be worn bushes, had similar symptoms on many other Land Rovers and Range Rovers |
13th Feb 2014 2:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35381 |
did it feel like the abs was coming on and off, if so then its the abs sensor.. |
13th Feb 2014 2:12pm |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Cheers Would it not happen all the time ? I think there was a advisory on the last mot I had. Is gat a big job ? Or DIY ? |
13th Feb 2014 2:14pm |
Don't know what thats like. Felt like the wheels were coming off |
13th Feb 2014 2:20pm |
i'm thinking if it was a dodgy abs sensor then you might get an intermittent fault...
13th Feb 2014 4:41pm |
Drove the FF home down the motorway 50 miles at 75mph ish no problem at all. Just my normal steering wheel shaking I've always had. Checked for faults, all clear. Checked my nuts all ok no height sensor fault either. Having the 4 wheel alignment done tomorrow so it may be that. |
13th Feb 2014 5:50pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8632 |
Possibly some deposits on the discs from standing for a week.
13th Feb 2014 6:22pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
i had similar wobble and it was my front left (nearside) brake caliper sticking. The rubber gromit inside had perished and causing it to stick. only wobbled at 50mph to 65mph. |
13th Feb 2014 6:43pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 900 |
Is it possible that having the car sitting for a week is the cause?
13th Feb 2014 7:44pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2581 |
Mike, take Johnnie Walker off the speed dial |
13th Feb 2014 7:49pm |
That's what it's like. It was like it was warming up early on, it was fine on the way home nothing at all |
13th Feb 2014 9:45pm |
Ok I had the 4 wheel alignment done today. Going one way on the front and the other way on the back . But all done now and felt good on the way home, steering straight. £50 not bad I thought. Still don't think it was the cause of the wobble tho. Could it be anything to do with the air suspension when going into motorway height ?
14th Feb 2014 8:50pm |
Ok Im still getting this wheel wobble. It's the same time on the motorway every time. I'll start the FF and pop 1 mile along the duel carriageway to pick up a mate, a couple more miles of duel carriageway, start stop to get onto the motorway. Then usually it's been 15-20 mins since start up. A couple of miles along the motorway 50-60 mph and the wobble happens, lasts for around 1/2 a mile then goes. Seems to be wobblier tho ! Do 40-50 mile trip, a bit of work for 5-6 hours then back down the motorway. Nothing at all, good as gold cruising down the road.
19th Apr 2014 8:21pm |
michele5041 Member Since: 25 Nov 2013 Location: Mansfield Posts: 11 |
I know it may sound daft, but could it be the 'motorway rut'. The track left by artics as they trundle up and down the motorway. History - Glutton for Punishment
19th Apr 2014 10:02pm |
