![]() | Home > General > D3 to FFRR |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have a 4.4 2002 with lpg. its essentially a bmw series 7 engine. (m62tu44) it is a superb engine. (same engine as the X5) .....7 series engines go on for 100's thousands miles....its a lightweight all alloy engine. it has vanos (variable valve timing) and four camshafts and 32 valves. the bores are coated with anti friction material. they run on synthetic oil, and will go very high miles. and stay very clean inside if oil regularly changed.
to follow up on lpg question, the answer is not a problemon the early engines, but suspect without flashlube (at the least) on later jaguar engines. the difference is the newer softer valve seats ie seat recession wear. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I looked into the LPG for my AJV8 and I wouldn't recommend it. The BMW engines seem very happy with it. I think an LPG BMW beats a TDV6 in just about every way.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
I can thoroughly recommend the 4.4 AJV8 |
Why not try an early SC and have all the benefits of a top spec'd car with great performance... |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
mac87 Member Since: 09 Feb 2014 Location: Kent Posts: 3 ![]() ![]() |
Thanks for that, I'd heard it could be pretty detrimental to some engines! I'm not totally averse to the idea of LPG but just wanted to know if it would damage the 4.4. Pardon my ignorance but did the engine change from a BMW to a AJV8 with the facelift?
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
I would just like to stick my toe in the door here and shout up for the diesel brigade!! I am a petrol head through and through, have owned a lot of nice fast powerful cars in my time and thought I would never own a diesel, but after years of V8 engine Discos and RR's of all sorts, I am currently running a TDV8, I think it is one of the best engines I have had for a long time and that is saying something for a self confessed petrol head!! it is quiet, economical and has more than enough power to satisfy. just to give some idea of things, I have 330bhp and just under 800Nm of torque and as we all know its the torque that makes you go forwards. I get full torque from very low rpm and I can honestly say I love it!! I have owned lots of LPG cars too, and now a days with the price of it and availablility or lack of it depending where you live in the country, diesel makes a lot of sense. I know you will get a petrol FFRR cheaper then a diesel, but there is no comparison between your TDV6 and a TDV8. worth a think. Current: TDV8 (3.6) RRS HSE
At least over here, the facelift coincided with the switch from the BMW engine to the Jaguar.
TugRR that's precisely the reason I'm going petrol, EGR and turbo gave me grief on the D3. A couple of friends of mine have the TDV8s and they really are lovely engines, but I like the relative simplicity of the petrol. |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
In a similar position here, although my D3 is still going strong at the moment! I've had it for the better part of 5 years now, and am considering changing back to RR (my last was an early P38 4.6, nearly a decade ago) ...
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
We have a 56 Reg Vogue with the Jag AJV8, (only had her a month mind), and she is LPG converted (2 years ago by previous owner) and runs like a dream 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
Arguably the early SC's are one of the most reliable 322's |
