Home > In Car Electronics (L322) > How long 'til battery drain?
kirton
England 2006 Range Rover Autobiography 4.4 V8 Zermatt Silver
Evening Folks,
I used to have a Grand Cherokee which if left in a long stay car park for two weeks with the alarms fully set the battery would be flat on return. I got over this by disabling the internal sensors. My question is. Do I need to do the same with my 2006 FFRR?
Cheers,
Smile
Post #240071 5th Feb 2014 8:26pm
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I have been suffering similar anxiety & am very interested in any views!
Post #240409 6th Feb 2014 4:32pm
Sorry chaps there is in good answer to this. If everything is working as it should then it will last for way over 2weeks.
However if there is a bit of a drain from something not shutting down properly, or if the battery is goosed through age/flattening/faulty alternator then the time it will last will be a lot shorter.
If you are worried the why not invest in a solar charger, plug it into the fag lighter and it will top up the battery whilst the car is standing Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #240451 6th Feb 2014 6:22pm
mjdronfield
Should the car not "go to sleep" as it were, after a day or so, leaving minimum systems alive ?
That's my understanding.
Like others suggest, it should last a couple of weeks. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #240457 6th Feb 2014 6:56pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
50mA drain when asleep on my 2002 Vogue.
MC
Post #240458 6th Feb 2014 6:58pm
T24RES
....get yourself breakdown cover, that'll sort it. Ian
Post #240472 6th Feb 2014 7:39pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
My solar panel wont do any charging in the front fag lighter only when i connect it to the rear boot charger does it charge.
Post #240714 7th Feb 2014 10:47am
Mistercorn
MC
Just to expand on this, if you have a 020 battery, about 100Ah, this will last for 83 days until fully discharged. Doing that would kill the battery so I would recommend a reasonable safe limit of 50% capacity, so about 5-6 weeks of no use should be fine and I would consider a reasonable maximum before a charge.
MC
Post #240726 7th Feb 2014 11:14am
If you are not confident about your battery staying the course when away there is a way round this which might be of use.
Fit a battery isolating switch between the Battery -ve terminal and the car body earth and switch the battery off when you leave the car.
You will of course need to lock the car manually with the key and you will have no alarm/immobiliser function for the duration.
If you wish to have the central locking and alarm/immobiliser working while you are away you can fit a second temporary battery to the car whilst you are away by simply having a 50-60AH (or more) battery with a fused lead on terminating in a accessory plug.
When leaving the car, switch off the main vehicle battery and plug the second temporary battery into any accessory socket that is live when the ignition is off. This battery will then allow the car to go to sleep normally including alarm/immobiliser and allow central locking to work when you get back to the car.
This of course assumes your car has no excessive battery drain. Depending on battery drain the temporary battery may or may not fully discharge but this is no worse than your main vehicle battery discharging as normal. You would of course be able to start the car by opening with the key and then switching the main vehicle battery back on.
I've tried this set-up, it works. Thumbs Up
Post #240735 7th Feb 2014 11:29am
steptoe
Why not just have the second battery in the boot and use it to jump start the car if the fitted battery is flat.
Rolling with laughter
Post #240829 7th Feb 2014 5:24pm
nwmgc
OK: my anxiety has eased... Thank you Very Happy
Post #242175 12th Feb 2014 12:41pm
