Home > General > What Tyre
What Tyre
Pressure do you run the 255x50x20 tyres on , some fitters say 36 Front 42 Rear, others say 32 Front 36 Rear so kinda wondering what most of you Gents run on ......
Post #20084 14th Jun 2010 12:31pm
sleepezy
Should be listed on a sticker on the drivers door shut - mine certainly was when I had a puncture on Friday!
I run 42 rear, 36 front (MY07 TDV8 20inch)
Should be varied depending on passenger load...
Post #20085 14th Jun 2010 1:17pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
^^^ This on 20" rims, without full passengers or luggage. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #20086 14th Jun 2010 1:25pm
That's what i run on 42 rear's 36 Front, but a Kwik Censored Censored told me they were too high ....... Whistle
Post #20096 14th Jun 2010 3:18pm
jayzee
They have no idea Rolling with laughter
Follow what LR recommend for a vehicle of this weight Thumbs Up Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #20102 14th Jun 2010 4:15pm
Worth noting that they have to cover their backs so you may fing the pressures a little high in the rear unless you have 4 adults plus luggage!!!
I suggest 34 front and 36 back when everyday driving with one or two in the front.
Post #20107 14th Jun 2010 4:58pm
jayzee
I was told by the local dealer in 2003, and confirmed again when I bought the S/C last year to stick to the pressures on the plate. Apparently, it helps with the notorious "cupping" the FF RR is known for.
Thought I'd share it Thumbs Up Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #20129 14th Jun 2010 8:20pm
But the difference between unloaded & loaded on the sticker is huge. You need to use your judgement IMHO.
Post #20140 14th Jun 2010 9:08pm
jayzee
Unloaded = 36 front and 42 rear on a 255/50/20
Loaded = 60psi all round.
There are no smaller values for the 20" rims, only the 18 and 19" Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #20148 14th Jun 2010 10:18pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I've always used the sticker pressure
Post #20150 14th Jun 2010 10:57pm
jayzee
Completely even tyre wear if going by the sticker, and the car really does corner well Thumbs Up
Put it another way - my mountain bike tyre pressures are between 40-50 PSI Laughing
Go by what the manufacturer says for each wheel/tyre combo. There is the a reason they have arrived at those values.
Now, we are all aware of non-standad wheels/tyres voiding your insurance... think about incorrect tyre pressures for a minute then! Whistle
Not only that, but you are seriously affecting the safety of you, passengers, and others with under-inflated tyres on such a heavy beast like the FFRR.
20" wheels are not as comfortable as 19s or 18s - FACT. If you are trying to get the levels of comfort of the smaller wheels by under-inflating 20s - well that's daft IMO, you should just stick on smaller wheels. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #20155 14th Jun 2010 11:03pm
