![]() | Home > Technical (L322) > Rear Disc's and Brake Shoe Q?? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I'd be inclined to check the handbrake shoes. A rub with some emery paper or similar will be all you need in most cases. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Neil, don't forget to back the handbrake shoes off before trying to pull off the rear discs sir... Last thing you need to do is pull the pins through the back plates |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
cheers guys, Craig yeah done that years ago on a ML oops |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 ![]() ![]() ![]() |
I read that if you release epb with engine on then turn off car the discs can be removed without need to wind back handbrake shoes? Present :2008 TDV8 HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Depends if they clear any lip on the inside of the drum |
