Home > Maintenance & Mods (L322) > Cubby box gas strut removal
Liszt
2004 Range Rover Vogue 4.4 V8 Buckingham Blue
I am trying to swap the oddments tray for the piece that is molded to take the phone holder. It has a hole in it which the gas strut for the cubby box lid passes through. How do I undo the strut at one end to fit this on?
Am I going to have to take half the centre console apart?
Cheers,
Mike
Post #19584 8th Jun 2010 12:30pm
daveo
hi mike, been here and done it when i was fitting the blue tooth..went and bought the pin so i could see what way it did come out. what you need is an automatic centre punch , use it on the end closes to the passenger 1 or 2 clicks and it will fly out, don't tap it with a hammer as the holder is only cast alloy and can break..
as your are sitting in the driver seat,look at the pin, it comes out on the left , so if you pushed it out it would be going towards the drives seat.
have i made that clear...
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #19605 8th Jun 2010 3:19pm
Liszt
Ok, so it just presses out. Have some thing that might work for that. Thanks,
Presume it just pushes back in with a bit of effort?
Post #19606 8th Jun 2010 3:29pm
daveo
hi, yes use a auto centre punch it will shock it out with ease V8 facelift Range Rover Autobiography 22" wheels.
Post #19654 8th Jun 2010 9:35pm
