Home > Technical (L322) > 2003 Range Rover HSE - Trans Failsafe Prog
flow11234
United States 2003 Range Rover Vogue SE 4.4 V8 Giverny Green
Im driving a 2003 range rover.Ok although it might have been asked before I can seem to find a answer.
Here's my problem... My truck starts up and I can move the shifter with no problem but for some reason my truck won't move at all,in drive there's nothing and reverse same thing. When I'm selecting the gears and then try to put it back into park I get a grinding noise. There's no check engine light on or anything. I test my battery it's 100% alternator is good. All the fuse seem to be working I checked it with the test light I'm at a lost please help...oh BTW my mountain(I think it's the lo range symbol) symbol light is on also it flashing instead of a steady light.
Post #231949 30th Dec 2013 3:02am
RRPhil
On a slope, will the vehicle roll forwards/backwards with the handbrake off and the gear selector in the Park position?
Phil
Post #231950 30th Dec 2013 3:06am
flow11234
While the truck is in park with the hand brake on it does not role when I release the hand brake it roles forward and back
Post #231951 30th Dec 2013 3:16am
RRPhil
Okay, so the problem is downstream of the transmission output i.e. an issue with the transfer box, propshafts, final drives or driveshafts. As your mountain symbol is flashing I would begin by trying to recalibrate the shift motor on the transfer box using Fuse 37 and let us know what the outcome is.
Note that the slot for Fuse 37 should normally be empty. A fuse is inserted here only to get the shift motor to select neutral in the transfer box in the event that the car has to be towed on its wheels.
Phil
Post #231992 30th Dec 2013 3:26pm
flow11234
Thanks I got it I love these forms it was fues 37
Post #232003 30th Dec 2013 4:08pm
alib123
hi rrPhil, sorry to hijack this thread but im told your the man to speak to. Please could you look at my thread re trans fail safe and give your opinion. Thanks in advance
http://www.fullfatrr.com/forum/topic22742.html
Post #232018 30th Dec 2013 5:32pm
