Home > Technical (L322) > Tapping Noise |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
I would guess a worn cam lobe, possibly being caused by a blocked oil way which improves when the oil is thinner whilst warm & able to get through. Would get the cover off check for wear & clear the oil feed pipes out. You could try a flush but best way is clean the oil feed first then flush to remove any other deposits Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
28th Dec 2013 10:46pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Could be one of the drive belts fraying at the edges! Previous cars:
29th Dec 2013 7:14am |
