![]() | Home > Technical (L322) > Fuel pumps!!! |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Mate I researched all the common failures on the 322 before biting the bullet. This being one of them.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
The thing that winds me up the most is that i absolutely love the thing!!
ewok |
I was gonna recover it to my local Indy but i decided that since it drives intermittently i've dumped it at my Grandfather's where i can do the pump myself and hopefully save a few quid!!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
You need to make sure you are changing the right pump or else it could be costly |
I know. I'll have to get it to cut out so I can get underneath and have a listen. The fault codes only tell me it's a fault on the low pressure system. I was assured that if I get the INJ SYS FAIL message then it's the in tank pump? |
you are right its intank |
Guys I've hunted high & low to try and find a part number or supplier for just the pump inside the whole sender assembly.
Are you sure it's the pump in the tank that's at fault?
Can you explain how could it be the one behind the wheel
Sorry guys i should have said, the one behind the wheel was changed a few weeks back. |
Found an aftermarket pump at a good. I'll copy & Paste across the part no and site once I'm back on laptop. |
So, it was booked in to my local Indy today for brake pipes and the pump didn't arrive till today too. Got it recovered over to the garage yesterday.
