Home > Technical (L322) > Annoying sounds
Oe_tuning
Singapore 2004 Range Rover Vogue 4.4 V8 Epsom Green
Annoying sounds
Hi guys,
Before I tear my car apart, might worth checking if anyone has the same experience Very Happy
Mine is a 2002 build with 4.4L petrol.
1) I hear squeaking sound everytime I press and release the brake pedal. It is silent after first startup and making sound after a while.
2) the grill on top of dashboard is vibrating/rattling when I'm idling on D. It's silent if I press the grill with my hand, but I dont see screws to tighten. What's under the grill? Center speaker?
Thanks,
Richard
Post #229783 17th Dec 2013 4:23pm
mjdronfield
The grille is just held on by clips, you can pry it up if you are gentle - but try not to bend it too much or the paint comes off.
As you predict, the centre speaker is under it.
Can be tight sometimes though.
I had a corner that sat a bit proud, so I took it off, bent it down a bit and replaced. Job done.
The speaker is held in by screws........
Not sure about the rest of your noises. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #229793 17th Dec 2013 4:44pm
Oe_tuning
Thank you mjdronfield...i'll do the grill first tom, sounds easy Smile
Post #229795 17th Dec 2013 4:56pm
Oe_tuning
Anyone else have squeaky break pedal? Smile
Post #230406 20th Dec 2013 12:56pm
inside the cabin?
if so spray some silicon lubricant on the mechanism... ... - .- -.
Post #230410 20th Dec 2013 1:09pm
Oe_tuning
Yeap...gonna do that tom Stan Smile
But i think i gotta open the steering wheel column cover to spray the mechanism.
Still researching for how-to on that.
Post #230463 20th Dec 2013 4:40pm
who's tom? Confused ... - .- -.
Post #230465 20th Dec 2013 4:44pm
Oe_tuning
Hahaha!!!
Stan, tom = tomorrow Very Happy
Post #230468 20th Dec 2013 4:52pm
ok = okay ... - .- -.
Post #230470 20th Dec 2013 5:03pm
