Home > Maintenance & Mods (L322) > Whirring and vibrating noise
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
I have done a lot of reading on this and none of the posts seem conclusive so here goes.
I open the car don't switch the ignition on and I can hear a whirring / vibrating sound that seems to be coming from behind the clock (not a ticking sound)
If I start the car it seems to be quieter but cant tell really as the sound of the engine. If I lock the car (and remain sitting there) it goes away.
I haven't had any battery issues or any other symptoms and all else seems fine, but this must be an early warning for something on its way out?
Any offers?
Post #229530 16th Dec 2013 1:14pm
record it on a mobile phone video....
Post #229531 16th Dec 2013 1:22pm
wealy
Done that - How do I upload it?
Post #229535 16th Dec 2013 1:45pm
you cant...you'll have to host it somewhere [youtube?] and place a link on the forum.. ... - .- -.
Post #229536 16th Dec 2013 1:46pm
btw, i get that whirring noise, me thinks its the ecu's or something behind the dash.. ... - .- -.
Post #229537 16th Dec 2013 1:47pm
wealy
And how doe I do that?
Post #229546 16th Dec 2013 1:52pm
i gather you've just recorded the sound , if so do a video this time and upload it to youtube and then paste the youtube link here.. ... - .- -.
Post #229547 16th Dec 2013 1:55pm
Yup YOUTUBE IT....
Post #229548 16th Dec 2013 1:57pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
Wealy
If it is still the same HEVAC as in my 03TD6 it is that ecu that open,closes and regulates the different valves on the vent/heating system as wel as it contains a few small ventilators for interior temp measurement
Post #229564 16th Dec 2013 2:46pm
jak480
And that Ecu wakes up when you open the door and goes back to sleep if you just sit in the car
Post #229566 16th Dec 2013 2:49pm
wealy
Thanks Jak - so no detriment to the workings of the car then?
Post #229568 16th Dec 2013 2:54pm
They all make that noise, some a bit louder than others, it's normal...just ignore
Post #229570 16th Dec 2013 3:02pm
jak480
I've noticed that after some time it you can consider to open it and clean it you would be surprised how much dirt you find in there (specially if somebody smokes)
Note never use a vacuum cleaner on those ciquitboards.
I ignore it until it gets really enoiying
Post #229573 16th Dec 2013 3:19pm
wealy
How do you open it to clean it?
Post #229581 16th Dec 2013 3:46pm
jak480
On mine I just pull the whole unit out and then it is a question to flip the plastic clips that holds the whole thing together
I'll try to get some pic later because I have a unit open
Post #229585 16th Dec 2013 4:02pm
