Home > Technical (L322) > 2010 4.4 TDV8 vogue |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I think you need to look at the calliper as if it's Brembo it will have it cast into the body. 2020 Porsche Panamera Turbo Hybrid (V FAST)
19th Dec 2013 10:47pm |
snowsports1 Member Since: 19 Dec 2013 Location: hampshire Posts: 5 |
ok thanks it doesn't, it says range rover so I will buy the non brembo discs. just looking at famous four website. |
19th Dec 2013 10:50pm |
You have the later ones, always an answer on here most of the time not from me as the others are proper boffins.
19th Dec 2013 10:55pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Yes sir you do have Brembo's if the callipers are grey with Range Rover on them... 10my onwards don't have Brembo on them only as yours are... Jas, yours too are Brembo's pal |
19th Dec 2013 11:06pm |
ok that was close now buying brembo discs and pads. the dephi pads are much cheaper mind you, are the genuine brembo pads worth it? |
19th Dec 2013 11:28pm |
Your car has the later 09- big Brembo's on it not the smaller 05-09 smaller Brembo's
19th Dec 2013 11:34pm |
IMHO I would only ever fit OE pads |
19th Dec 2013 11:35pm |
I want bigger Craig make them bigger for me Present :2008 TDV8 HSE
19th Dec 2013 11:47pm |
20th Dec 2013 12:02am |
Thanks Craig
20th Dec 2013 10:12am |
No worries |
20th Dec 2013 10:15am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
At least you have brakes. My TD6 with a full trailer load......it does stop eventually. |
20th Dec 2013 10:50am |
What makes you think I was referring to brakes Kurt Present :2008 TDV8 HSE
20th Dec 2013 11:14am |
Because I've met Craig and he didn't do that for me.
20th Dec 2013 12:11pm |
