![]() | Home > Technical (L322) > How do I remove my "removable" tow bar?? |
Look under the rear of the car and there is a bolt with a spring going through it. Remove the spring, then the bolt and the receiver will slide out giving you much better access to the lock and key |
The turny thing the key goes into to be pulled out (or pushed in - can't remember!) and turned after the key is inserted |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Hmm could be a mare , they are supposed to be taken off every few months and oiled and greased , i left one on for 2 winters and it had to have the lock drilled out to get it off |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 ![]() ![]() |
![]() ![]() ![]() ![]() ![]() ![]() Clear as a bell now then!!!!!!!???????????? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
just took mine off for the winter..... insert red key upside down. turn it back and forth a bit to get it in the mood. you need to turn it from stop position a half turn clockwise ie 180 degrees. then, you need to grab and pull the black knob, and twist it around half a turn clockwise and it should drop off. if not, gently tap it from underneath and or rattle it. there are two ball bearings that lock from the hook, and into holes in the receiver. if they are not dropping back, then it wont drop. don't go banging the hell out of it. it could just be (on yours) the key is not releasing the inner part. but its definitely 180 degeres and then pull and twist
lastly if you only have one key, you might want to get another (convetional key) off the bay for £2 delivered. it gives you a little more leverage and stays on your keys so not misplacable ... number in keyhead search 'westfalia key' |
Ok. So I've finally managed to get some time to have a proper go at getting the towbar apart.... I've taken the whole bar out of the receiver to make access easier (that was a job in itself!). Anyway, I've spent a while trying to get the key in, but I'm not even sure the key fits particularly well - it doesn't go in straight at all, either way round.
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Thats the right type of key |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8683 ![]() ![]() ![]() |
Apart from doing what you are doing, then not really any ideas, other than checking you are trying to put the key in the right way round.
I would keep putting the key in and out while the oil is in there and give it a wiggle.
Did you do what i said and put loads of wd40 or similar in there over 2-3 days ? it looks bone dry to me. should be flooded with release oil for a couple of days , also keep it as warm as you can so the oil stays thin, the release part of the oil agent will evaporate off so keep throwing in more wd40 in the key slot as well as previous
If that does not work it's a drill out job and lock change i am afraid
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
All of the above! The key does not appear to go in the right way round. A lot of jiggling with a fair bit of in and out motion then all of a sudden it will turn! Loads of WD 40!
So you have got it all the way in and turned the key ? Far to many gone... |
