Home > Technical (L322) > Gearbox banging?
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Gearbox banging?
Hi, looked at a range rover today and when i went to accelerate while pulling away there was a bang, felt like it jumped out of gear. Drove fine the rest of the time, nice and smooth, no slipping, bad changes, etc. Trying to replicate the problem it would only happen when the steering wheel was turned left or right and hard acceleration, absolutely fine accelerating normally
Any ideas?
Dont want to buy a lemon....its a 52 4.5 v8 130k
thanks
Post #228646 12th Dec 2013 6:18pm
winslo
I mean accelerating hard in a straight line was fine, and accelerating normally with the wheel turned left or right was fine, just hard accelerationg with wheel tuned either direction if that makes sense?
Post #228647 12th Dec 2013 6:20pm
Citrus Buyer beware!!!!
Post #228651 12th Dec 2013 6:26pm
Dolphinboy
Front Driveshaft probably. Either needs replacing or the warranty change to the newer flexible coupling not done?
Post #228654 12th Dec 2013 6:34pm
