Home > Maintenance & Mods (L322) > trans-failsafe-prog.
henry nelson
England 2003 Range Rover HSE Td6 Adriatic Blue
Hi everyone, just had trans-failsafe prog come up on my car. Had the codes read and are as follows, no 85-can bus transfer box time out. no 37- gear monitor s fault. can any one tell me what this means and what I need to do. Does the gear box need re-calibrated, it was re-built last year.
Post #227209 5th Dec 2013 5:52pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
I had it once and the motor to engage the low gears needed to be changed.
Post #227554 7th Dec 2013 5:53pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
^^^^ Yep, could very well be the transfer shift motor. Does it go into low and back to high range ok?
You may also get the message if the battery is not tip top. I used to get it when I'd left it for a week or so..... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #227598 7th Dec 2013 11:18pm
henry nelson
trans-failsafe
Hi both sorry it took so long to reply, it turns out all it needed was all the error messages deleted from the computors, there was at 50 of them for the suspension a loan so managed to find an independent where I was staying near Carlisle and he cleared every thing that was wrong, runs fine now, cheers.
Post #227748 9th Dec 2013 8:02am
Have your battery looked at then sir... Whistle
That many faults without a hard one usually comes back to bight you in the arse at some point imho... Whistle
Post #227751 9th Dec 2013 8:18am
henry nelson
trans-failsafe
Cheers Craig, it had a new battery last year when gear box was re-built but I will get it checked. The garage that cleared the faults said that they had not been cleared right, so I hope nothing comes back. cheers.
Post #228018 10th Dec 2013 12:18pm
